Cup holders in a hot rod?
Discussion in 'The Hokey Ass Message Board' started by Kevin Lee, Jan 4, 2010.
  1. Kevin get yourself one of those swinging holders for a boat, and hang it off the dash like they do in a speed boat.
    I'll look when I get home I have a link to a place that sells 'em. They're chromed wire lookin' thingys.
  2. unkledaddy
    unkledaddy
    Steel hot rods need magnetic cup holders!
  3. BinderRod
    BinderRod
    They were called bar bouys. You can still get them at Bass Pro. I think the would look like shit.
  4. lostforawhile
    lostforawhile
    I remember people having them in the 70's kept the beer from spilling, back then they would just make you dump it out, if you were toasted they gave you a ride home. :)
  5. unkledaddy
    unkledaddy
  6. zman
    zman
    from Garner, NC
    I have one of those cheap plastic ones on the seat of the Buick. Works pretty well. Well enough that I've not made a little console like I was planning.
    Not only do they have them at boat supply stores, but they have a bunch of other cool stuff.
  7. 39 All Ford
    39 All Ford
    from Benton AR
    There is no way that thing is strong enough.
  8. swade41
    swade41
    from Buffalo,NY
    Couldn't you just weld an exhaust clamp off of a bracket on to the backside of your glove box door ??? Better thought how about useing the muffler clamp and cutting two oblong holes near the bottom of the dash. Push the clamp through the holes,nut and washer on back side. It would sit neatly flush like a mini rounded grab handle to pull it in and out to use.
  9. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Saw a car here in Tucson, had cupholders that said Coca~Cola from a 1940's shopping cart. That was cool, sorry no pics. Basically chrome wire construction.
  10. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Or you could modify a GM Kleenex box to swing out and hold a couple drinks....
  11. Ryan
    Ryan
    ADMINISTRATOR
    The ultimate solution in my book... I found this on a '32 in Ohio... It's an old wood box with an engined turned lid that slides open via an early ford dash knob.
    If you make one, go ahead and make 2... cuz my 39 needs one.
  12. Christie
    Christie
    spaghetti can cut in half painted and pin striped, self tapping screw into the floor and your good to go. ;o)
  13. 29nash
    29nash
    from colorado
    No cups for me, Lone Star, can or bottle. That space between my thighs on the seat is all I have ever used.:D
  14. unkledaddy
    unkledaddy
  15. Cosmo49
    Cosmo49
    oops, looks like $95 bucks to me...
  16. EV34
    EV34
    heres one that i save out of the garage of my great grandmothers place when she passed away last year i thought it was cool and worth saving thinking it might look good in the 48 ford pickup we got sitting around
  17. yankbuilt
    yankbuilt
    Heres what I did.Stole this from a 2000 dodge ram.Was the adjustable cup holder found in the back seat that was mounted under the console.Then mounted it to the bottom of my seat.Works really well and you don't see it when pushed in.
  18. roddinron
    roddinron
    Well Kevin, a very wise man once said-
    "If the women don't find you handsome, they should at least find you handy."
  19. the-rodster
    the-rodster
    Ten bucks at overtons.com
  20. unkledaddy
    unkledaddy
    Tried to Photoshop that out, but couldn't post it afterward.
  21. OhioRiv
    OhioRiv
    No holes to drill, no messy adhesive...
  22. Terry O
    Terry O
    Kevin,
    What better "solution"?
    1.Does the coffee cup fit?
    most coffee shop cups fit in standard 1" tape rolls but if you need the Big Gulp size
    just move right on up to the inch and a half roll of tape.
    2.Does it tip?
    if it tips, your greasy side is up.
    3.Does it slide?
    if it does, watch out for #2
    4. Color doesn't match the interior?
    hey they got lots of colors or spray your roll any color you like. Tired of the color? Peel a little off start again.
    5. Is your duct tape/cup holder buddy, a financially sound investment?
    Well about $5 gets you set up and if it becomes encrusted with floor grunge another $5
    will replace it and the old roll goes into the garage , not the trash.
    6. Can you use your duct tape/cup holder for anything else besides holding your coffee?
    Come on Kevin, you know the answer to that.....hell that coffee holder has literally gotten me home at least a couple of times and made my life easier every day it sits on my floor.
    I'd like to help you with a solution but What's the Problem
    Terry
  23. 61TBird
    61TBird
    [​IMG][​IMG]
    Winner!
  24. Terry O
    Terry O
    Ryan,
    a couple of things you might want to consider before putting this in the '39-
    Lid needs to be removed to use. Where you gonna put it and those corners look like they could do some damage.
    Your gonna spill drinks into the wood box and that could get nasty quick if it's not easy to clean.
    Terry
  25. How 'bout a connecting rod hooked ovet the shifter?
  26. HOTRODSURFER
    HOTRODSURFER
    from HATBORO,PA
    PERFECT! thanks kev i have the same problem when i drive my 53 f250!
  27. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Thats them! I want a set for the '50 Burb
  28. NortonG
    NortonG
    Much like the one Ryan posted.
    I was thinking that a cigar box would look pretty rad.
    Open the lid and have a cup holder and a spot for some change.
    They come in a bunch of shapes and sizes.
    Norton
  29. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    I need one, I normally fire up the T and get some coffee on Saturday mornings. That thing is a pain in the dick to drive one handed as the posi pushes you through the corners and hand signals are almost useless!
    I'll have something rigged in my '35 for sure.
  30. lostforawhile
    lostforawhile
    you make the cupholder insert able to be lifted out, and coat the inside with something like thompsons water seal. that way anything that spills can be wiped out.
