Cupholders with a bench seat
Discussion in 'The Hokey Ass Message Board' started by tanof, Jan 4, 2011.
  1. lostforawhile
    lostforawhile
    There was a thread somewhere on here all about some custom holders, actually some pretty cool stuff created by people on here, I just can't seem to find it. MY off topic Lincoln doesn't even have a lousy holder, I was reminded of this today when I wasted a really good cup of coffee by spilling it all over my legs. They aren't that untraditional, just make something cool, if you are mounting it to the seat bottom, you can always do what I did, and use a little pneumatic cylinder to make it slide in and out with some hidden ****ons, All you need is the cylinder, a couple of vacuum solenoids that self vent when they aren't powered, you can find them in emissions controls at any junkyard, and one of those little plastic vacuum canisters, everything can be mounted out of sight, I used a rocker switch that reverses voltage, like a power window switch, very cool trick to push the ****on and it pops out. something like that would be at home in any custom. PM me if you want more details on this.
  2. zman
    zman
    from Garner, NC
  3. lostforawhile
    lostforawhile
    thanks, I like this one
    the finned cover would actually look pretty good flat black if it was permanent, but I think he wants something that hides away
  4. dt50chev
    dt50chev
    Funny how many people open a post on cupholders just to complain about it. If I see a post about pink plaid seatcovers and know that I have no interest, I don't even open up the post and look at it. To each his own.
  5. 49ratfink
    49ratfink
    point was that if I needed a cup holder I'd buy, build or steal one, not come here for advice on what to do.:cool:
  6. 49ratfink
    49ratfink
    good for you. that is why the HAMB is straying away from it's original intent. HOT RODS and Customs, racing, history... stuff like that.
    I say we turn this into a ***** fest until it gets closed.
  7. zman
    zman
    from Garner, NC
    Then say that instead of...
    and grow the **** up already. :eek::eek::eek:
  8. lostforawhile
    lostforawhile
    he's building something for his interior, I don't know why it's off topic, He could have slapped a cheap walmart cupholder in, but he wanted to fabricate something that looks cool instead, There was some stuff that was fabricated in the other thread that took a lot of time to make, when is making something yourself so far off topic? it's no different then making anything else custom for your interior. he's not making it into a modern car, just adding something useful so he doesn't spill his coffee, they had things to hang on your door to hold your drink all the way in the 50's,are they as off topic? seems like if they are that old they would be traditional by now. I found one from way back that was heavy chrome plated steel, too rare to risk something happening to it, but still cool
    disturbio likes this.
  9. MO_JUNK
    MO_JUNK
    from Rolla, Mo.
    I drive a 57 chev. pickup with a bench seat. I like to drink coffee going down the road. I took an old push through center cap from a specialty/aftermarket wheel, and attached a round magnet(from a portable cb antenna) to the base. The magnet is so strong that it holds even through the rubber floormat. I painted it with some zinc chromate primer and it's done. It holds all the common 16-20oz. convenience store cups (throwaways). Simple but it works and you can move it around wherever you want it. Traditional-Hell I don't know. Sam
  10. lostforawhile
    lostforawhile
    as to the original idea, what you need is some round aluminum bar stock, the tube, not the solid, the inside will need to be machined to the diameter of a can, or coffee cup, or whatever, then three holes get drilled spaced evenly around it's perimeter, after this is done, use a cut off tool in the lathe to machine off a section about an 1/8 or so thick, countersink for some machine screws, and drill the holes in it big enough for the screws to slid through, the bottom piece will get tapped for the screws, cut a hole where you want it in the upholstery to the INSIDE diameter of the top piece, now mark the screw holes on the upholstery and use a punch to punch them out, the bottom piece goes under the hole, and the top piece over it, once it's screwed together, it will sandwich the upholstery between the two halves, the bottom will need to be anchored somehow, but that depends on what it's in, you will need to create some sort of bottom for the holder too of course.
  11. hotrod37
    hotrod37
    from Indiana
    I'm sorry, I didn't reqd this complete thread but here is what I did.
    I used a Walmart(?) plastic version that had a flat part to fit down between buckets, I ***ume.
    Mounted to a board and then mounted that board to another using "L" brackets. The last board is thin enough to fit under my seat.
    So it slips under my bench seat and the cupholder stands up in front of my seat.
    I have an auto shifter so as longg as it get into drive, I'm good.
    But it works for the wife and I for trips.
    I added a plastic tub in front of the cupholder to hold other stuff too.
  12. antique baby seat that has arms ...fits over top backrest put old lunchbox herman munster style in it open is cup holder closed is just old stuff
  13. tanof
    tanof
    from New Mexico
    This just in!
    TORONTO – A pilot's spilled coffee accidentally triggered a hijacking alert and caused a United Airlines flight from Chicago to Frankfurt, Germany, to make an unscheduled stop in Canada.
    A Transport Canada report said United Flight 940 was diverted to Toronto late Monday and landed safely at Pearson International Airport. In a twist reminiscent of the plot of the 1964 Glenn Ford movie 'Fate Is the Hunter', the coffee spill caused distress signals to go out, including code 7500, which means hijacking or unlawful interference. ...
    Another vehicle that needs a cupholder! Now can we cut the **** and just post suggestions or constructive criticisms? I have see three that I like and am looking into already to put into my truck.
  14. 40Standard
    40Standard
    from Indy
    I love this photo. Wonder if she bakes cookies?
  15. lostforawhile
    lostforawhile
    she might have dropped a few down there, and can't find them, but would you risk losing a couple of fingers to retrieve a cookie from her? thats like having a steak in front a gator, you might lose some fingers in the process :D
  16. serape29
    serape29
    from colorado
    I was once told if its hard to drive with no extras its a hot rod, if you want that drive the old lady's mini van. i always hold my beer with my legs like my dad taught me.
  17. Deuces
    Deuces
    Figures...:rolleyes:
  18. zman
    zman
    from Garner, NC
    Guess you don't like customs then. Of course the angel hair headliner serves no purpose, so it's just an extra. :rolleyes:
  19. serape29
    serape29
    from colorado
    hahaha i never do what i am told! I figured i would get called out on that, but no cupholders lol
  20. Cymro
    Cymro
  21. Rs2
    Rs2
    Bring the thing to us ... we'll build you something that will work ~~~
  22. cool57
    cool57
    When my wife worked in ICU (as RN) a biggun' came in, way bigger than the upholder gal. She had to undress and bathe the gal....she found a sandwich :eek: under one breast. The gal said "Oh yeah I was savin' that honey."
  23. R Frederick
    R Frederick
    from illinois
    I've been thinking about this one, and I think I have a good idea. I always need a spit cup handy when I drive. Anyway, there are a good variety of these available from fancy to plain stainless steel wire. They are very cheap and plain, and will bolt directly to just about anything. You could make a bracket for them onto the front of your bench seat. Water bottle cages for bicycles.
  24. FANTM58
    FANTM58
    Have a look at the Pull n pay type yards,
    You sopuld find some sort of retractable unit ?
  25. When I was young and dumb and full of . . . I used to balance a bottle of beer between my legs while I was driving. But I don't drink and drive any more.
  26. Racecarr
    Racecarr
    I have a solution. I make a steel bomber bench seat with cuphplders. Goto www.ironace.net. Just an idea?
  27. zman
    zman
    from Garner, NC
    Nice. first post is SPAM. no intro. Hmmm.... :rolleyes:
  28. Damn Rocky that is like sooo 20 minutes ago. I mean wow man when are you going to check into the 21 century.
    I think we have made progress myself we have gone from Pomade and Cuffs to cup holders and A/C units.
  29. R Frederick
    R Frederick
    from illinois
    If I shouldn't have a cupholder, you can hold my tobacco spit can for me.:)
  30. Gator
    Gator
    from Statham Ga
    Every vehicle my Grandad owned had a thick paste of tobacco juice all down the drivers side, never saw him spit in a can or bottle... he chewed 'twist' too :p
