Hot Rods Curious tool
Discussion in 'The Hokey Ass Message Board' started by Dave Gray, Apr 4, 2024.
  1. Dave Gray
    Dave Gray
    A friend just showed me a tool today that he has owned for many years. I had never seen one of these before. Anyone familiar with this tool? IMG_5055.jpeg IMG_5056.jpeg
  2. squirrel
    Does it include the instructions? this is from the interwebs from a past auction of one
  3. Oneball
    Oneball
    Yep it’s peening hammer. Used for peening (stress relief).
  4. TCTND
    TCTND
    Is that intended to expand collapsed piston skirts? Reduce slap and noise?
  5. Oneball
    Oneball
    No, it changes the surface structure of the material not its shape. In very very simplistic terms it makes it stronger
    tractorguy and chryslerfan55 like this.
  6. TCTND
    TCTND
    Actually, that's a little too simplistic. Peening as it is commonly used puts the surface in a state of compression which causes it to resist cracking. This makes the part more resistant to breaking but not really stronger. Peening a relatively thin section can also expand it which is why I speculated as to this tools purpose. We won't really know until someone comes up with the complete instruction sheet.
  7. Dave Gray
    Dave Gray
    winduptoy likes this.
  8. squirrel
    so of course you have to scan/photograph all of them and post here, for posterity...
    Tow Truck Tom and Budget36 like this.
  9. BJR
    BJR
    So am I understanding this correctly, the hammer head moves like a hammer should while the handle doesn't move? All powered by air.
  10. ClayMart
    ClayMart
    Good scans of the instruction sheets would be very helpful. ;)
    If the tool is still in working order, then a video (even a short one) of the tool in use on an old, s**** piston would be the "icing on the cake"!
    :D
    RMR&C likes this.
  11. Dave Gray
    Dave Gray
    Photos of the instructions. IMG_5090.jpeg IMG_5086.jpeg IMG_5087.jpeg IMG_5088.jpeg
    Beanscoot, ClayMart, squirrel and 2 others like this.
  12. ClayMart
    ClayMart
  13. 19Fordy
    19Fordy
    Never saw that tool before. Thanks for posting all the info.
    Deuces likes this.
  14. moonman29
    moonman29
    Very interesting. Thank you for posting.
  15. 38Chevy454
    38Chevy454
    This is correct. Peening results in the surface to have compressive stresses, which improves fatigue cracking resistance. It does not have enough depth to affect strength of the material, being only a few thousandths typically. Shot peening is a similar end result as this manual hammer peening. Valve springs are one example part that has shot peening done, as they obviously go through numerous cycles - which is what fatigue is. Thousands and thousands of stress cycles that are in the eleastic range (below the yield strength). Fatigue cracking is NOT because the metal got weaker, like when you think of your muscles fatigued from work. Totally different, but uses the same base word. Fatigue in metals is where there is repeated cyclic tensile stress, and a crack can initiate and propagate. Eventually this crack becomes too big and the part experiences catastrophic failure and breaks due to overload; since the remaining uncracked portion can not support the operating load.
    ClayMart likes this.
