Hot Rods Curious: Who all's got Model A's in the works?
Discussion in 'The Hokey Ass Message Board' started by Mike Zenor, Oct 18, 2005.
  1. Abomb
    Abomb
    Here's mine, it's not completely traditional though........
  2. Glen
    Glen
    I should clarify this picture, several people PM'd me about the suspension. The torque arm is not pictured yet because my block is still at the machine shop and I need it to make the arm the correct length. Torque arms are on 3rd generation Camaros, it uses two trailing arms and one arm that locates on the pinion and goes up to the u-joint at the transmission.
  3. HotRodMicky
    HotRodMicky
  4. Glen
    Glen
    That inner body frame runs up and under the window making a package tray like shelf the fuel cell will mount under it.....so its actually above the axle and behind.
  5. -Brent-
    -Brent-
    I've got one coming, finally, thanks to a fellow HAMBer.
  6. norton
    norton
    Here is my '29.
  7. JRRoberts
    JRRoberts
    from Madison WI
    The two that are in my garage.....
  8. Von Rigg Fink
    Von Rigg Fink
    from Garage
    well its probably going to be in progress for a while , but I have a 28 Tudor My daugher and I are building. Only pictures I have of it are parts and pieces
  9. blacknwhitedog
    blacknwhitedog
    from Sonoma, CA
    Here's mine, pickin it up this weekend.....
  10. Von Rigg Fink
    Von Rigg Fink
    from Garage
    heres one
  11. T__N__A
    T__N__A
    model A....
      32.6 KB
      34.5 KB
  12. abonecoupe31
    abonecoupe31
    from Michigan
    I've got 7 of them.....and now building a new ch***is for my chopped 31 A coupe that I hope to have rolling by the end of the month, and maybe on the road this summer if all goes well.
    I think I found the right car for me...I'll never have another hot rod than a Model A....unbelievably, they still seem to get hauled out of barns from time to time....
    you guys are proof positive that they make a fine hot rod.
    Mark
  13. Ryan
    Ryan
    ADMINISTRATOR
  14. 5wbomber
    5wbomber
    just a couple of mine:D
  15. Toast
    Toast
    from Jenks, OK
    I just Bought a rolling 30 Coupe, but don't have any pics yet. I'm going to keep it full fendered and full hood and run a 2 deuce 215 alum Buick motor. Pics to follow.
  16. Tindall
    Tindall
    30 Coupe Chopped 4.5 on 32 rails
  17. SaltCityCustoms
    SaltCityCustoms
    I would show you pictures of mine but it's "top secret", I will tell you that it's a 29 Sedan thou.
  18. modelamac
    modelamac
    It's not really in the works.. I just finished it! what do you think, this it the first car I have every built from the ground up myself... and with help from a few friends! it's a 28 Tudor.... rust free body! I will have to get some photos up of my 28 Roadster that is in the works posted soon!
  19. propwash
    propwash
    from Las Vegas
    Mine's not quite "in the works" except in the sense that TRUE hot rods are never done....next step is either paint, chop it a couple of inches or sell/trade and move onto the next project - probably a roadster.
    http://s285.photobucket.com/albums/ll70/propwash62/
    dj
  20. phatbaby
    phatbaby
    Here's my 28 here .....i been working on it and about ready to hit the road to atlanta in june or maybe the Run What you Brung in May...its a 2x4 frame ..6inch chop..117 in wheel base...reverse corvair and 36 radius rods in back and 46 front....z'ed 12 in front and 16 in back.what do ya think????/
  21. Cad La Dave
    Cad La Dave
    from CA
    Is that a new cyclone? Either way its a *****in piece...
  22. phatbaby
    phatbaby
    Oh well my pictures didn't upload...i'll agin later..
  23. moefuzz
    moefuzz
    This is about how far I am right now (April 12th) - after about 60 hours of wet sanding and polishing (last January during -42 degree temperatures with the shop heater going full blast).
    I bolted some mags up to the ch***is a week or two ago.
    The polishing rag is holding the door from marking the B pillar. No door bumpers installed yet.
    The reflection of a future stude truck project. The bright red spot is were I tried blocking the flash with my thumb.
    I laid the flames out about 2 months ago just before we sprayed the last coat of epoxy primer/sealer.
    I wanted the last coat of sealer sprayed on in black to darken any tones of the future red paint.
    Then.....,
    The actual (color) paint code was a Chrysler red,
    The flame job was laid out from a photocopy of the pics from about 2 months earlier (pics above).
    After we were done color sanding, we shot two coats of clear over the red paint and scuffed the clear to give the flames something to bite onto.
    We used a pounce wheel and blue chalk to mirror the image to the opposite side of the body.
    The flames are a purple pearl.
  24. dsiddons
    dsiddons
    from Indiana
    Moefuzz that paint is unreal..... I hope mine has half that shine. [​IMG]
  25. glenn33
    glenn33
    from Browns, IL
    Still a little early for pics at this point. I've started on a '31 frame. Have the motor mounts in and partially boxed. I've got a Ford 8" and dropped front axle. Engine is early 350 and have found a Saginaw 4 speed for it...I've gathered several other parts, and of course it will be running a Rebel Wire harness, but no body as yet. Looking forward to getting back on it now that all the other projects are done.
  26. 067chevy
    067chevy
    30 model a coupe in the works
  27. vegas
    vegas
    I have a 29 coupe that is in the VERY early stages. So far, more gathering parts than anything! I have the body (already with a VIN and ***le too), an 8.8 Ford rear axle, all the replacement sheet metal, and a running 331 hemi that I just pulled out of a 53 Town and Country wagon. I suppose this project will take me forever, but when it is driveable, it will be worth it! :D
    -Corey
  28. SATANSSHO4
    SATANSSHO4
  29. SATANSSHO4
    SATANSSHO4
    shuting my computer off now the more time i spend on here the less i get done[​IMG]
  30. Aman
    Aman
    from Texas
    Mine's about half done. I need to wire it and do the interior and a bunch of other stuff.
