Custom bead rolling....lotsa pic's
Discussion in 'The Hokey Ass Message Board' started by Kiwi Kev, Nov 25, 2006.
  1. Da Tinman
    Da Tinman
    Also take a look at www.metalmeet.com lots of Horrible Fright bead roller builds.
    Just so ya know I'm still rollin'
  2. BadLuck
    BadLuck
    wow.....these blow my mind....what a talent.....
  3. 29bowtie
    29bowtie
    Check the "Tech Archives" for a superb example of a Modified HF beadroller, you'll be shocked.
  4. no bux rod
    no bux rod
    Richard D & Bowtie29,
    Thanks for the links. Looks like there are a lot of reinforcement schemes that will work. Time to look at the angle iron collection.
    For you guys who have added a gearmotor, what is the best roller speed? I have seen a few running at 3 RPM. (My guess feed speed of 24"/ minute) How fast is too fast?
    Is there a need for a reverse when rolling or does that help create s****.
    N B R
  5. You will find reverse comes in handy if the panel won't fit in the machine to reach a part of the picture/pattern and you have to feed it from the other side. Sometimes you may need to feed from both sides to roll a pair of panels with mirror images. Hard to explain but take my word for it, you will need the reverse function sooner or later, not to roll lines backwards but to roll them forward from the other side (told you it was hard to explain). I don't think you can have a motor that's too fast because you control the speed with the foot pedal and only go as fast as you need.
  6. Durod
    Durod
    from DFW, Tx
    someone do a HAMB panel...
  7. I always liked Hydro man! I made this one to sell. I have a couple of panels in the cl***ifieds, sorry about the spam.
  8. Royalshifter
    Royalshifter
    Moderator
    Dammm you that is cool.
  9. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    Nice!
  10. Da Tinman
    Da Tinman
    BTT!!!
    How's about some simple pleats???
    This ones going to get painted black to match the car, and the blank spots in the center are gonna get some airbrush emblems and such in there.
    what have the rest of you rollin fools been up to???
  11. Sracecraft
    Sracecraft
    Nice!
    Would you explain how you create the pleats?
    Craig
  12. Da Tinman
    Da Tinman
    AAAaaaahhhhh, would you think I was an ***hole if I wanted to keep that one to myself???
    Its the same process that BigWigRaceCars uses for his diamond pleats, at least I think it is. Lets see what he says first. Its his trick, I just figured it out.
  13. Sracecraft
    Sracecraft
    No I wouldn't think that at all. But I have tried it before, and the results were not what I was looking for. Maybe a hint, aw come on please! That's cool I'll keep working on it.
    Craig
  14. BigWigRaceCars
    BigWigRaceCars
    from Austin, TX
    I don't mind sharing some techniques at all.
    For the pleats, I use a tipping die on top. The bottom die has a very shallow V cut in it, probably 1/2 inch wide but only about .040" deep. And, I don't even run the dies at full depth. I turn the crank maybe 1/3 of a turn after contact with the panel. I can take pictures of the dies tonight when I get back home if needed. I use the same dies for doing pleats, diamond tuck, spider webs, and checkered flags. Some examples below:
  15. BigWigRaceCars
    BigWigRaceCars
    from Austin, TX
    Here's one more recent one, done with step dies. It looks unbelievable in person!
    VintageConcepts likes this.
  16. Da Tinman
    Da Tinman
    There ya go!
    My way is close, but I use a flat lower roll, with 4-5 layers of electrical tape. it will warp the hell out of it, but when you work it out over your knee it gives the pleats a little more dome.
    Nice work on the door panel!!!
  17. BigWigRaceCars
    BigWigRaceCars
    from Austin, TX
    Here's a few more recent ones. I posted these previously on one of the Friday Art shows, I think, but they probably ought to be in this thread...
  18. thats very nice.
  19. Sracecraft
    Sracecraft
    Thanks to both of you guys for the tips! Your work is amazing!
    Craig
  20. Holy ****. You guys are masterbeaders!
  21. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    Ha Ha Ha !
  22. 60'shotrod
    60'shotrod
    Some people have too much talent!Outstanding work.
  23. Skrap metal
    Skrap metal
    holy smokes! i can't believe what i'm seeing here, friggin amazing!!!!
  24. blackmopar
    blackmopar
    from fallbrook
    wow - that diamond pleat is bad***, and the drawings/signage you guys do are some of the coolest **** ive ever seen - beyond my comprehension
  25. Skrap metal
    Skrap metal
  26. woodscavenger
    woodscavenger
    from idaho
    What's it take $$$$ to get a basic setup to try playing with this type of work?
  27. BBPanel
    BBPanel
    from DFW
    Pretty slick - wouldn't have another set like that for my 66 Nova would you? -Bob
  28. Da Tinman
    Da Tinman
    Maybe good be arranged,, PM me if your in the market!!
    How much your bead roller setup cost depends on who you get it from, mine is a Mittler Bros, very high quality and ready to run right out of the box. You'll also need a few different sets of rolls to go along with it. the roller itself is $625 and comes with one set of rolls. I have 6 sets of rolls, including tipping dies, and a stripe roller.
    I have used a MB roller for most of my carreer, used and abused, more like it. I have never bent or broken one. For me it was an easy choice. Their customer service is second to none as well.
    Do a search for bead roller mod threads, you can get a decent roller cheaper if you are willing to beef up a cheaper one.
