Custom bead rolling....lotsa pic's
Discussion in 'The Hokey Ass Message Board' started by Kiwi Kev, Nov 25, 2006.
  1. Skrap metal
    Skrap metal
    i gotta ask, how are you guys getting such sharp lines when two corners meet, and you
    gotta switch directions????
  2. BigWigRaceCars
    BigWigRaceCars
    from Austin, TX
    It's really just about practice. There's no trick to making sharp corners. If I want a sharp corner, I just roll up to the corner and stop about 1/8" short, release the tension on the rolls, rotate the panel 90-degrees, crank the dies back down again about 1/8" past the corner, and roll the next side. The stop/start points are what's critical, and that's what comes via trial and error. The same is true for pointed flame tips, only you're rotating the panel 180-degrees and you need to move it over by an amount equal to your die offset so that you don't crush the other bead.
    It's also possible to turn quite sharp corners without even releasing the dies. I can do a 1/4" radius turn without any problem, but again, that takes lots of practice. Also, it really helps to have a powered bead roller and a table to support your workpiece. That way, both hands are free to guide the panel.
  3. Da Tinman
    Da Tinman
    Here's a door panel I just finished for a gl*** 32 roadster that is being built for the salt. Satin black finish is bad***!
    Quality control inspector!
  4. BigBlockMopar
    BigBlockMopar
    Very cool.
    Gives a new meaning to Tuck 'n' Roll I guess.
  5. Chevytruckin98
    Chevytruckin98
    from Tx
  6. neonloverrob
    neonloverrob
    from newton, ks
    That has got to be the coolest bead work I've ever seen!! I been wanting to try it myself, now I have to! I had no idea that one could do all that with on of those things.
  7. eddytheb
    eddytheb
    WOW I am not one to be impressed easily but that tin work is awesome.
  8. Da Tinman
    Da Tinman
    Heres some of the other tinwork in the car, it still has the mylar on it so it looks a little funky.
  9. stealthcruiser
    stealthcruiser
    Thanks, Tinman............I bet the Mylar on there while you work it makes it dream to maneuver through the dies..........
  10. Made this as a bithday present for Royalshifter.....
  11. Da Tinman
    Da Tinman
    Pretty Sweet Kev!!!
    Yeah its a life saver, most of what I do uses the prefinished stuff and surface damage during the construction of the piece means its trash!
  12. dodgerodder
    dodgerodder
    Man, I wish I could do a SMALL fraction of the stuff you guys do with a bead roller. I can finally (by cheating) do a straight line:eek:
    Dan
  13. skullhat
    skullhat
    boy....to all who posted their work, unreal talent.
    i cant get over the one by bigwig with the g***er lettering, very impressive, couldnt imagine pulling that off.
    also diggin kiwi's tin work, the clay smith door panels are awesome, as is the crows logo
    glad i stumbeld on this thread
    skull
  14. stirlingmac
    stirlingmac
    Jeez, Kev...most people would struggle to draw that ch***is with a pen let alone roll it, beautiful work mate.!!!
  15. BigWigRaceCars
    BigWigRaceCars
    from Austin, TX
    Here's some more of mine from the past few months.
    Driver of the Year award for a VW forum that I sponsor:
    Various VW door panels:
    Some wall art:
    A 3-sided wind block for the "Still Smokin' It" BBQ team. Approx 48" wide.
  16. Irrational Metalworks
    Alliance Vendor
    from DFW
  17. gotwood
    gotwood
    from NYC
    Tin that is cool as heck. That roll and pleat is sharp idea.
    The VW stuff above is on a whole new level...... Is that done with a bead roller or running a template through a wheel or ?????? I can't see how that is possible with a bead roller and those tight lettering radius.
    How flat are the panels when you guys are done with them? Do you put a bend or radius into them 1st???
    WOW!!
  18. Flipper
    Flipper
    from Kentucky
    Holy ****! That's a lot of bead rolling on one panel. :eek:
    How in the heck do you plan something like that out? Do you happen to have any in-process pics of any of the complex designs to show how you got from flat sheet to a freakin' work of art?
  19. BigWigRaceCars
    BigWigRaceCars
    from Austin, TX
    Yes, it's all done with a bead roller. The tight radius for lettering and such took me a long time to master. The best tip I have for someone trying to do complex beading (other than the obvious of practice, practice, practice) is to make a table to hold your workpiece. That way you aren't having to try and hold up the panels and can concentrate solely on following the lines.
    The panels with regular step rolling in them will stay pretty flat. The ones with pleats or diamonds want to curl up somewhat, but I just flatten the panel back out gently across my leg after all the bead rolling is done.
    Yes, that one took me longer than any other one I've done yet, for sure.
    I don't really have any in progress shots of the crazy ones. I have some more to do within the next week or so that has some text in the design, so I'll try to do***ent it.
  20. mosimpson
    mosimpson
  21. BigWigRaceCars
    BigWigRaceCars
    from Austin, TX
    Yes, I'll post some later tonight. I have them at home.
  22. Blase
    Blase
    Wow truly amazing work! Can you post up some close up pitures of the panels? Everything I have tried to do ends up really scratched up from the rollers. How are you getting around this "problem"?
  23. Da Tinman
    Da Tinman
    I use delrin rollers not steel on aluminum, saves a lot of marking, also make sure the all the corners on you rdies are lightly rounded, that saves some marking as well. But the biggest thing to stop marking is a protective coat. All of the stuff I use has a mylar coating. If your alum doesnt have a coating talk to your local sign maker and get some transfer tape and cover it yourself.
  24. BigWigRaceCars
    BigWigRaceCars
    from Austin, TX
    I get my sheets with PVC on them, then peel off the PVC after all the work is done. Otherwise, use nylon or delrin rolls. Mittler Bros and Pro-Tools make most of their dies either way - steel or nylon.
  25. Wicked Tin
    Wicked Tin
    Damn that is so cool. I think I know what my next garage tool is going to be!
  26. ZRODZ
    ZRODZ
    How'd you train your bead roller to do all that great artwork? Mine must be really dumb.
  27. custom_lettering
    custom_lettering
    from Wall, NJ
    wow i'm glad this old post came back. i never seen it. great stuff
  28. Da Tinman
    Da Tinman
    Threaten it with a hammer.:D
  29. 36 ROKIT
    36 ROKIT
    Wow, again, guys; amazing work! Not just fine craftsmanship, but creative and artistic,
    as well.....
  30. BigWigRaceCars
    BigWigRaceCars
    from Austin, TX
    Here's what mine looks like. The table is 36x36 inches, so it easily supports something big like a door panel. There are outriggers under the table that connect it to the bead roller and support the right side plus 2 legs that support the left side. Everything DZUS's on so I can take it off if I need to.
    The bead roller itself is a Pro-Tools machine that I have cut apart and lengthened the throat on to 42". I use this one for all my fancy work in the aluminum. I also have a Mittler Bros 36" machine for the heavy stuff.
    The white stuff under the bead roller table is my raw material with the PVC (white plastic stick-on sheeting) still on it.
