Folks Of Interest Custom car shop in Maryland?
Discussion in 'The Hokey Ass Message Board' started by StefanS, Aug 6, 2025.
  1. StefanS
    StefanS
    from Maryland
    Are there any that do chop tops that anyone knows of? I've found a few that do muscle cars and race cars but customs are a bit different
  2. lothiandon1940
    lothiandon1940
    Might be a good idea to mention the car that you are looking to chop. '30's era cars are something that a talented craftsman might be willing to tackle, but could shy away from a later model car. It's more involved than it might appear and don't forget all of the garnish moldings will need to be cut to match the new profile. Then there is the matter of all glass needed after the chop. When you see a project for sale that has already been chopped, but no glass has been installed, there's usually a reason. Not trying to be a Negative Nellie here, but just make sure whoever you find knows what they are doing. If it's your Shoebox Ford in your profile picture, yes they've been done hundreds of times, so a competent body man should be able to do the task. Keep asking around at events that you might attend. I'm guessing you may find a good retired bodyman or a small shop. Obviously a BIG shop will likely be much more expensive and may want to build the whole car for you at LARGE $$$$. Good luck....Don.
    19Eddy30 and Just Gary like this.
  3. chopolds
    chopolds
    from howell, nj
    The Hot Rod Garage. High end custom and rod builders.
    Charlie K likes this.
  4. lothiandon1940
    lothiandon1940
    ....Outstanding work, but pricey for sure.
  5. StefanS
    StefanS
    from Maryland
    so I ended up buying my '51 Bel Air back. What I want to do is replace the three-piece rear glass with a coupe roof rear section, so not exactly a chop but more of a graft.
    I'm sure everyone's familiar with '51 hard tops and coupes but if not, the coupe has a shorter roof line than the hardtop which is what I'm looking for
    lothiandon1940 likes this.
  6. StefanS
    StefanS
    from Maryland
    I sent them an email last night so I'm just waiting to hear back from them at this point. Hopefully they can give me a "semi quote" over the phone cause they're pretty far away from me
  7. alchemy
    alchemy
    How big is Maryland? A few days drive from end to end? If you want quality, I doubt the local cave and pave body shop would be able to do the work.
  8. StefanS
    StefanS
    from Maryland
    Very true
  9. lothiandon1940
    lothiandon1940
    ...Not sure where you are in the state, but you might want to put your "general" area in this post and on your profile page so other locals might see it and know where you might get the work done. There's also a sub forum on here for Maryland members that you might want to check out. edit: Well, there used to be a Maryland sub-forum.:(
  10. StefanS
    StefanS
    from Maryland
    I didn't know either of those things was a possibility on here but I'll definitely get it taken care of. I'm just outside of Frederick
  11. Hellfish
    Hellfish
    Since you're in Frederick, expand your search to PA, VA and WV, all of which are close to you
    lothiandon1940 and Just Gary like this.
  12. StefanS
    StefanS
    from Maryland
    I'm game for any of them to be honest
  13. Just Gary
    Just Gary
    @ClutchDumpinDan at Old Dominion Speed & Custom in Fredricksburg, VA did a beautiful job chopping a shoebox Ford.
  14. 19Eddy30
    19Eddy30
    from VA
    Near Winchester Virginia down 81 ,
    About 1 hour from Frederick Md
    Place in White Post , custom , coach & restoration shop,
    Between Front Royal and Winchester Can not remember Name , been around for many years
    Posie in Pa maybe 1-1/2 -2 hrs
  15. StefanS
    StefanS
    from Maryland
    Does posies work on them? I knew they make leaf spring but I didn't think they actually had a shop
  16. StefanS
    StefanS
    from Maryland
    I'll check them out for sure. The problem is getting the car down and dropping it off and then finding a way home.
  17. 19Eddy30
    19Eddy30
    from VA
    Do not know for sure now , over the years they built a few class show vehicles and seemed to remember their name being attached to other builds besides just spring,
    @ one time they had a T shirt referring to chopping Top's, a character with a big chainsaw
  18. hrm2k
    hrm2k
    There might be a waiting line and it might be $$$$$ but for this area, nobody better than Cody Walls
    http://www.traditionalmetalcraft.com/. His latest work…chopped, sectioned, channeled and more than I can think of IMG_2272.jpeg IMG_2228.jpeg IMG_2017.jpeg IMG_2016.jpeg IMG_2015.jpeg
  19. Fitty Toomuch
    Fitty Toomuch
    from WVa
    Might call Bucky`s in Martinsburg, they may be willing to take something like that on, maybe not? worth the call.
  20. StefanS
    StefanS
    from Maryland
    Is Bucky's the name of the shop?
  21. Fitty Toomuch
    Fitty Toomuch
    from WVa
    Yes. Bucky`s LTD Auto Body
  22. Hellfish
    Hellfish
    Hire someone to drop it off. There are plenty of transporters on the HAMB, plus people local to you. Yes, it will cost, but it will be a drop in the bucket relative to the cost of the custom work you're wanting.
  23. Fitty Toomuch
    Fitty Toomuch
    from WVa
    Bucky`s son is a master with paint.
  24. dirtpoor
    dirtpoor
    from maryland
    You could try bad donkee hot rods in Hanover PA. JR does good work.
    Just Gary likes this.
  25. hrm2k
    hrm2k
    Bad Donkee folded its tents a couple of years ago. You might try Clark Bates in Abbottstown Pa. @Clark He does great work and his backlog shows it
    Just Gary and lothiandon1940 like this.
