found these in the basement. Had them cast locally ages ago, all suitable vehicles are long gone. These are sandcast aluminum, gates are cut, but you'll to put some effort into them. design is raised on a 1/4" background. Can be drilled and tapped. This is the last of the batch, note that the shape of the bottom is slightly different between the 2. $25 each, $42.50 for both thanks.
