Technical Custom cut glass, what should I expect for quality?
Discussion in 'The Hokey Ass Message Board' started by tlmartin84, Aug 21, 2024.
  1. tlmartin84
    tlmartin84
    from WV
    I ordered some one piece side windows for my '56 F100 from a rather large online custom gl*** company. Each piece is cut, I ***ume by hand. When I received the cuts, the edges are bumpy and not flat.
    All edges are wavy, the bottom, and two sides will hide, but I'd think at least the top should be smooth.
    Is this typical for custom cut gl***? Do I just accept it? I am just not sure what to expect and don't want to be over **** about it if that is the best that can be done.
    tractorguy likes this.
  2. TA DAD
    TA DAD
    from NC
    I would expect the same edge every door gl*** has, smooth and evenly finished with no defects. I don't get how someone would even send that out as a finished product.
    reagen, nunattax, 29A-V8 and 8 others like this.
  3. rockable
    rockable
    Were the patterns you made smooth and consistent? If not, there's your first mistake.
  4. MMM1693
    MMM1693
    I have had gl*** cut for 4 different cars and that does not seem kosher to me. It has all been flat gl***, cut by home garage guys and gl*** companies, but all had smooth straight edges. Yes I would have concerns. Good luck, Dan
    Spoggie, tractorguy and twenty8 like this.
  5. tlmartin84
    tlmartin84
    from WV
    I didn't send them patterns, I just selected the vehicle on the website.
    seabeecmc and rockable like this.
  6. guthriesmith
    guthriesmith
    I would expect much better quality than what you received unless It was from the lowest cost provider possibly. Whatever the case, I would want nicer edges on the gl*** whether I cut it myself or paid to get it.
  7. twenty8
    twenty8
    Not acceptable........ and by the way, I am a glazier. That is a very poor result.
    Spoggie, 49ratfink, oldsmobum and 6 others like this.
  8. larry k
    larry k
    All edges should be sanded smooth and straight , with out any chips , man that is some piss poor gl*** work !!!
    Okie Pete, 29A-V8, Unkl Ian and 2 others like this.
  9. TA DAD
    TA DAD
    from NC
    It will be interesting to hear the companies response.
    29A-V8, Automotive Stud and twenty8 like this.
  10. tlmartin84
    tlmartin84
    from WV
    They told me I could sand it with any grit, just keep it wet and cool....
  11. tlmartin84
    tlmartin84
    from WV
    I don't know where else to order it from.....
  12. guthriesmith
    guthriesmith
    I would hope it was cheap with that kind of response. Amazing the lack of quality that people think they can actually sell today.
    Lone Star Mopar and Unkl Ian like this.
  13. twenty8
    twenty8
    That is true, but it will be time consuming.
    Are they going to pay you for your time to correct their less than ideal work?
    Is it tempered gl***?
    Unkl Ian and guthriesmith like this.
  14. TA DAD
    TA DAD
    from NC
    That is funny , I would have to try and get my money back if for no other reason just on the principle of they are a hack .
  15. TA DAD
    TA DAD
    from NC
    Now you have patterns ( close ) anyhow
    guthriesmith likes this.
  16. alanp561
    alanp561
    Where are you in WV? I just googled gl*** companies in Huntington and there are at least 10 and it looks like most of them do auto gl***. When I needed flat gl*** for my '46 Mercury, I looked up gl*** suppliers in Chattanooga and there were several who would make them a heck of a lot cheaper than buying them online. The ones I got had clean, finished edges. That piece of yours with the wavy edge looks like early morning Monday or late Friday work.
    reagen and firstinsteele like this.
  17. I supplied a local gl*** company (one that does not specialize in automotive gl***) with two panes of cracked auto gl*** (one door window, one half of a split front window) that I wanted to them copy. The gl*** I got back had very poor edges, clearly they didn't sand/finish the edges. I ended up sanding them myself (by hand) and had no issues. That being said, from a company that supplies replacement gl*** specifically for autos, I would fully expect the gl*** to be "installation ready". But, after bringing this to their attention and hearing their response, I don't think you have any other option that to sand it yourself.
  18. twenty8
    twenty8
    I would recommend checking how accurate they are before relying on them as a template.
    The quality of the pieces supplied does not inspire confidence........:confused:
  19. alchemy
    alchemy
    Sure he has another option. Cancel the credit card payment. I’m sure Mastercard can see how ****py the job was with those pics.
  20. tlmartin84
    tlmartin84
    from WV
    The entire kit was over $545.00 Inluded 2 channel strips (have to bend myself), the felt wipers (generic I have to cut myself) and the smoked TEMPERED gl***.
    Unkl Ian likes this.
  21. tlmartin84
    tlmartin84
    from WV
    I'd be shocked, most order and install..........nothing custom. If it is custom it is all laminate and not tempered.
    05snopro440 likes this.
  22. twenty8
    twenty8
    Can you put up a link to their website.
    nunattax and lemondana like this.
  23. twenty8
    twenty8
    Be very careful sanding the edge of tempered gl***. Easy to lose the whole shebang..........
    Shaping and edgework are done prior to the tempering process.
  24. sidevalve8ba
    sidevalve8ba
    I don't know where you are in West Virginia and I do not know who you got your gl*** from but that is second rate work at best. I have had all my gl***work done locally and I have always been very happy with their work. Plus if I have a problem I have someone local to go to.
  25. tlmartin84
    tlmartin84
    from WV
    Im in Lewisburg area.
    I haven't found anyone within an hour, even willing to order and install a windshield.
  26. tlmartin84
    tlmartin84
    from WV
    I haven't named them yet, wanted to see how they handled it before I bashed them openly. They are a pretty well known/large supplier though. They pop up on quite a few forums.
    Okie Pete likes this.
  27. TA DAD
    TA DAD
    from NC
    After them telling me to sand it myself I would bash them to no end !
  28. squirrel
    I can't get good work on gl*** cutting locally any more....it's overpriced, and takes forever, and doesn't quite match the template I give them, and the edges aren't finished like they should be.
    so unfortunately it might be "as good as it gets", but seems to me if you had asked here about where to get gl*** before you ordered it, you might have got some advice pointing you to a better place?
    good luck...
  29. 19Fordy
    19Fordy
  30. el Scotto
    el Scotto
    from Tracy, CA
