Technical Custom cut glass, what should I expect for quality?
Discussion in 'The Hokey Ass Message Board' started by tlmartin84, Aug 21, 2024.
  1. Unkl Ian
    Unkl Ian
    Unfortunately, only one real way to prove that a piece of gl*** is TEMPERED.
  2. Happydaze
    Happydaze
    But it has been seemingly successfully sanded by the op. Do we therefore deduce that it's not been tempered, as it sure seems that way?
  3. nrgwizard
    nrgwizard
    from Minn. uSA
    Tempered gl*** is a spl gl*** that is formed &/or cut to size, then heated to a specific temp & cooled. Don't think you can un-temper it, although I've never tried. If tempered gl*** is finished correctly, the edges will be smooth & shiny as the sides. Disrupt the edge by scratching or sanding & sooner or later(sometimes maybe like "right now"), when the surface-tension gets disrupted enough, the gl*** shatters into little chunks.
    Laminated gl*** will have 2 pieces of gl*** w/a plastic layer between them. Can cut, sand, etch, etc, w/o destroying the piece(cutting it wrong here doesn't count... :) ). When broken it will fracture in lines or starburst(s), but stay together, usually only one side breaks, unless impacted very hard. Edges will be smooth, but rarely polished.
    If that piece is just single-layer gl***, I doubt that's "safety gl***", since the edges looked rather rough. & since it's been sanded, better get busy polishing the edges. What you did works very well on laminated gl***, for future reference. I've used a DA w/wet(spritz bottle) wet-or-dry sandpaper in varying grits to almost polish the edges, after a long board to get it smooth-n-straight. Kinda messy, but it works & a hell of a lot cheaper than long belts.
    Me, I'd go thru the CC co complaint dept., return the gl***, get it local. If you really need/want tempered gl***. Or do laminated gl*** yourself. Gl*** cutting isn't *that* hard. :) . I've done curved windshields, flat laminated gl***, flat std gl***, stained gl***, etc.
    Since you're close, I'd use Lloyd. Probably should use him anyways... :D .
    Also, most places that cut or make auto gl***, will use the correct stamp on a corner stating what it is. If no stamp, probably don't want it... Since I haven't dug into "legalities" over/about that, idk. Might want to look it up, iffen you're concerned.
    FWIW.
    Marcus...
  4. Happydaze
    Happydaze
    They're actually double glazed, as in having an air gap between the layers.. At the edges the layers can be seen, but I'm not sure if this means it's laminated gl***, or gl*** that's been laminated!!
    Chris
    Unkl Ian likes this.
  5. Unkl Ian
    Unkl Ian
    Now that you mention it, I have heard of this on new Mercedes etc.
  6. tlmartin84
    tlmartin84
    from WV
    This has turned into a spirited discussion.
    There are videos of it being sanded successfully with guys that say you can, and videos of it busting into 1000 pieces. I do believe heat has a lot to do with it in the failures. The gl*** gets extremely hot, tries to shrink as it cools, and then explodes, due to the stress at the point of heating.
  7. twenty8
    twenty8
    The temper of gl*** can be removed by what is called annealing. This is when the gl*** is heated to a specific temperature and then cooled slowly. It can then be re-tempered by again heating, and cooling rapidly.
    This is not something you can do at home!
    With regards to the OP's gl***, my guess is thay it is not tempered. Break one and see.......
  8. alchemy
    alchemy
    If he can see the plastic layer in the middle, it’s not tempered, just laminated. A clear pic of the edge will show us.
    reagen and Unkl Ian like this.
  9. twenty8
    twenty8
    ........ or worse, just ordinary annealed gl***.....:eek:
  10. twenty8
    twenty8
    "Hold polarised lenses or sungl***es up to the gl***. Rotate the lens and look for spots that darken — this indicates the gl*** is tempered. Polarised light reacts differently when p***ing through tempered gl*** due to a strain pattern induced by heat strengthening during manufacture."
    Ever notice your car windows "rainbowing" when you are driving with your sunnies on?
    Happydaze and 46international like this.
  11. Unkl Ian
    Unkl Ian
    Nope.
    Probably because my sungl***es are not Polarized.
    twenty8 likes this.
  12. 57 Fargo
    57 Fargo
    You can see it in the sun sometimes as well
    Unkl Ian and twenty8 like this.
  13. snoc653
    snoc653
    from Iowa
    This sounds interesting. I don't normally wear polarized lenses unless I'm boating as they aren't recommended for use in aircraft (they can cause the electronic flight instruments to disappear if you look at them wrong). But now I want to dig a pair out and see how this looks on tempered gl***.
  14. 57Fury440
    57Fury440
    I wouldn't want to fool around with the gl***. You paid for a part that should fit and look right. Them telling you to sand it smooth is insulting. If it was that easy, then why wasn't it done that way in the first place. What you did seems good but listening to some of the gl*** guys on here I would be afraid that the gl*** is not tempered. The picture of how they sent it to you is horrible. I can't see how any reputable company would do that.
    Unkl Ian and leon bee like this.
  15. snoc653
    snoc653
    from Iowa
    If they were OK with the quality they sent you, go ahead and post their company name. They should be proud of their work and we certainly want to know who ships that kind of work. It does look better than the gl*** currently in my 51. Of course anything with out the bullet holes and clear packing tape has to look better.
  16. twenty8
    twenty8
    Now that must be laminated or ordinary annealed gl***. You can't put bullet holes in tempered gl***.........
    sidevalve8ba and Unkl Ian like this.
  17. snoc653
    snoc653
    from Iowa
    Both back windows are indeed laminated. Fortunately nobody was back there at the time. It was in one side and out the other.
  18. nrgwizard
    nrgwizard
    from Minn. uSA
    Hey, 28; I kinda figured that large specialized gl***-forming/making mfrg shops could de-temper gl***, but I was thinking home shops, just didn't mention it. Guess you'd need a rather large kiln, timer & accurate thermometer. & some material for testing... :D . Would be fun to try though...
    Marcus...
    & I also kinda like laminated gl*** for flat-side-gl***, instead of tempered. It may not crumble when hit, but it also doesn't allow things to come through, either. Well, not often... & I can cut it as needed. :) .
    & then there's always someone who could do this in a very large homemade kiln for back-gl*** chopping for customs. Apparently, "it's the Answer... :D ". Hey!, maybe a new sideline gig for Lloyd... :D .
    alanp561 and sidevalve8ba like this.
  19. Lloyd's paint & glass
    The last picture shows that this is not laminate. The gl*** looks horrible. And yes I would love to know who sold you this. I take pride in my skills, but I'm always beat down by the "ol Joe's super gl*** company" ********. Most shop for cheapest price, not best value. Post their name to save other guys the h***le please
  20. alanp561
    alanp561
    ^^^^^^^What Lloyd said
    warbird1, winr and TrailerTrashToo like this.
  21. 19Fordy
    19Fordy
    Be sure to seal the edges of the gl*** so as to keep out moister and prevent delamination.
    Properly cut gl*** should already come sealed. by the maker.
  22. K13
    K13
    The shop agreed to refund the OP his money and he refused it. What more are they supposed to do? They made a mistake, admitted it wasn't good enough and offered a refund sounds like a pretty stand up company to me.
    reagen and seabeecmc like this.
  23. Lloyd's paint & glass
    OK. Still wanna know who it is. That's not your business is it? Better yet, I'll continue to do it myself. I do good work.
    nunattax, sidevalve8ba and alanp561 like this.
  24. twenty8
    twenty8
    I think the real safety concern should be whether the gl*** supplied is actually tempered or not.
    If it "sanded" as easily as the OP described, I have my doubts........o_O
    guthriesmith, alanp561 and Happydaze like this.
  25. nrgwizard
    nrgwizard
    from Minn. uSA
    Splinter-City, man... Cut you like Mack-the-Knife.
    I'm not getting why no shop-naming, either. Not all of us want that quality...
    Marcus...
    alanp561 likes this.
  26. oldsmobum
    oldsmobum
    from SoCal
    “Sorry we f’ed that up. What you need to do to correct our shoddy work is start over and do it yourself.”
    It should have never required a second phone call to get a refund offered. The fact that it went out the door like that sinks their credibility; I wouldn’t be confident that the gl*** is actually tempered properly or at all.
    alanp561 and Lone Star Mopar like this.
  27. nunattax
    nunattax
    i got new gl*** cut local for my chev 38 pu all flat gl***.laminated windscreen and rear window .door gl*** is toughened.all cut on cnc gl*** cutting machine.i cut accurate templates from 1/4 " mdf with a jigsaw with new blade. sanded all edges.gl*** came back with perfect bullnose edges i was and am very happy with the job.gl*** was sent out to be toughened .total price 150 euro 14 or 15 years back. jim carter truck supplied paper templates i glued to the mdf
    60 Special likes this.
  28. tlmartin84
    tlmartin84
    from WV
    Well,
    It's not quite like that...........I didn't refuse it. But, there has been very little communication with the company, short one liners in emails are the best responses I got. They didn't offer to pay for shipping or send a return label. Return shipping was going to be $60.00.
    I don't know if you have ever tried to file a claim against a shipper, but it is a h***le. I figured the odds of it getting broken in shipping were pretty high, and at that point, he probably wouldn't refund my money, or would make a fight over it. So I decided to cut bait. Live and learn.
    These came from VINTAGE GL***.
    klleetrucking likes this.
  29. snoc653
    snoc653
    from Iowa
    Thank you for posting the company. I understand exactly how it is when you need to return something. A supplier sent the wrong part on an order I made. I emailed the salesman and explained the situation and asked for a Return Merchandise Authorization (RMA) to send their part back and asked them to ship the right part. Wound up calling the company and speaking to someone else, they said they would ship the right part and to just ship the other part back. The correct part showed up without the RMA label to return their part. I still have their part until I receive the shipping label for it. I’m not paying for their mistake and I don’t blame you for fixing the problem yourself rather than take the chance on shipping it back and forth and them expecting you to pay shipping each way.
  30. The gl*** shop can regrind the bumps out, take it back and request it.
