custom dashboards
Discussion in 'The Hokey Ass Message Board' started by ltex old iron, Aug 7, 2009.
  1. ltex old iron
    ltex old iron
    can we see some transplanted dashes or some dashes made from scratch..
  2. philly the greek
    philly the greek
    from so . cal.
    Here's mine that we made from scratch
  3. LeadSledMerc
    LeadSledMerc
    Here's my '37 Chevy with a 51 Olds cluster. I still need to add polished accent strips in the vent areas once I decide how I want them.
  4. bloodyjack
    bloodyjack
    my work in progress
  5. Jdee
    Jdee
    This is not custom dashboards but its a lot of cool dashboards.
    Restoration stuff.
    From Mr. Bvlgari's collection.
    A big video hope it plays.
    http://www.woodgraining.com/BIGVIDEO/
    Jdee
  6. evil1
    evil1
    I shortened and reshaped a 1936 Chevy truck dash to fit and used a GMC military gauges insert for my 1930 Durant
    Before
  7. 66Newport
    66Newport
    Man, that spedo is freaking awesome!
  8. cleatus
    cleatus
    from Sacramento
    52 Buick dash in my 40 Chevy. I had to section it down in about 10 pieces to get the gauges to be centered over the column and spaced evenly. The center grill is from the 40 chevy dash.
  9. HOTRODPRIMER
    HOTRODPRIMER
    Looks like a old Harley-Davidson motorcycle cop speedometer. HRP
  10. NTAPHSE
    NTAPHSE
    Wow, that looks a lot like a 51 Kaiser cluster!
  11. Last edited by a moderator: Jun 1, 2014
  12. I like all of the dashes shown so far. Does anyone have any pictures of a custom dash for a 61 Coupe DeVille? I would love to change mine.
  13. jaransont3
    jaransont3
    This is the 49-50 Ford Dash I picked up to use in my OT Sled project.
    It had to be narrowed about 9 inches to fit.
    Took out about an inch or so to the left of the large main gage bezel in order to get the gage centered on the steering column. Also took out about 4" on either side of the speaker grill to get the width right and save the grill and the clock location.
    This is what it replaced...
    and here it is installed...
  14. Jerry27Tub
    Jerry27Tub
    Heres the dash I made for my 27. I used the model T top rail and formed the bottom half to curve around my Champion gauge panel.
      536.8 KB
  15. Ghost28
    Ghost28
    I've showed this before. But it is a 51 buick dash narrowed 12 inches. Using all the stock guages, glove box, and buick door trim molded to the dodge door trim. Mounted in a 38 dodge pickup cab, or what's left of one,,,John
  16. marks914
    marks914
    Alliance Vendor
    That is bad***, holy cow.
    Nice job
    Mark
  17. Mark H
    Mark H
    from Scotland
    This is the dash in my '29.I filled the stock dash then cut the centre out.Then I 'turned' some stainless on a drill press and installed it from the the rear of the dash.I've since re-done the insert with the outer gauges a little lower.
      500.6 KB
  18. lucky
    lucky
    handmade, all steel and bolts in...late-model, but work is work I suppose
  19. chaddilac
    chaddilac
    Here's mine...
    Before:
    After:
    and my 50 ford dash all chopped up!!
  20. brigrat
    brigrat
    from Wa.St.
    Morphing a '42 Pontiac to a '36 Ford 3/W .......................
  21. strike a poser
    strike a poser
    from Salinas,CA
    What type 3 are you working on? It looks interesting.
  22. motoandy
    motoandy
    from MB, SC
    29 Chevy in a 29 ford
  23. raprap
    raprap
    from Ohio
    This is my dash. I started with a "*****in" dash then modified it to fit cleaner. The top, bottom and center are separate so it is very adjustable.
    I purchased Cl***ic "Vintage" gauges, cream faces with red pointers. The gauges are 3.5" in diameter. The headlight and wiper controls are clunky and they will be changed soon to be hidden. I have a "start ****on" on the dash from a 1950's airplane. The Clock on the right side of the dash is my own creation. When purchasing the gauge pack, I ordered an addition cluster that was empty. I scanned the existing background in on the computer and made my own clock face. Placed a continuous sweep quartz movement behind and it's done. The Chevrotlet script on the dash is from a 1958 Impala glove box. When installing the A/C, I sheet formed a panel that bolted it to the bottom of the dash. This houses the A/C controls, vents and Stereo. The lower dash also helps to conceal the condenser under the dash. Lower left drilled aluminum handles open the hood and trunk.
  24. 40fordtudor
    40fordtudor
    gorgeous---
  25. 57den
    57den
  26. Pat Thompson
    Pat Thompson
    I kno this is too new but,it's a dash I hand laid in a 97 chevy pickup.
  27. jeffrob
    jeffrob
    that is beautiful
