Technical Custom Edelbrock step up springs
Discussion in 'The Hokey Ass Message Board' started by harris73085, May 11, 2021.
  1. harris73085
    harris73085
    Has anyone seen stronger than 8 inHg step up springs? I'm pulling about 18 inches at idle and when I stomp it to wot, I get the slightest lean dip. Looking to see if I transfer to the power mode a little sooner will help. I've already tightened the air valve to the max recommended abs it helped a lot. Thank you.
    Sent from my SM-G981U1 using The H.A.M.B. mobile app
  2. saltflats
    saltflats
    from Missouri
    Can the accelerator pump be adjusted to help?
  3. harris73085
    harris73085
    Top hole using 43 squirter. It did improve it , just no more adjustment left.
  4. saltflats
    saltflats
    from Missouri
    Are you using a vacuum advance?
  5. 6sally6
    6sally6
    Could you slightly stretch them some?
    6sally6
  6. harris73085
    harris73085
    Vacuum advance is connected to ported Vacuum abs is about 15 more degrees.
  7. harris73085
    harris73085
    I didn't think of stretching, but have thought about using the spring from a click pen. I read on here that the pink was actually the strongest when someone measured them.
  8. saltflats
    saltflats
    from Missouri
    Have you tried it on manifold vacuum?
  9. harris73085
    harris73085
    I haven't, easy enough to give a quick try. Will I need to readjust my idle screws move, or just the idle speed when on manifold?
  10. harris73085
    harris73085
    Gave full vacuum a try and it didn't fix it. Feels the same as ported. That being said it is the tiniest little dip, maybe I'm being too critical. I will still try finding a stronger spring to give it a whirl.
  11. egads
    egads
    Do you have one of these? Strip kit. [​IMG]
  12. harris73085
    harris73085
    Yes I do. Currently running the silver 8inhg spring since I pull 17 inhg at idle.
