Technical Custom gasser leaf spring setup question (with diagram)
Discussion in 'The Hokey Ass Message Board' started by jugheadjones, May 7, 2019.
  1. jugheadjones
    jugheadjones
    Hi all,
    Please see diagram attached. Sorry for the poor quality.
    My (silly) question is:
    If the chassis isn’t running horizontal or is stepped should the leaf spring eyes still be inline with each other (like diagram B)?
    Many thanks,
    Ross
  2. seb fontana
    seb fontana
    from ct
    B will give better spring action/ride being able to absorb/flex for road irregularity's and fact "C" would even be a little better [rear eye lower than front eye] but A or C difference from B would have to be alot..Couple inches not a worry..
  3. jugheadjones
    jugheadjones
    Thank you. If the difference between the eyes is within 2” we should be ok then?
  4. We never mount the front spring Eye higher than the center of the rear axle.
    You get less spring wrap up this way. The factory does it this way. Picture .. B.. Works well on a trailer where the axle is not trying rotate up.
    Hightone111 and jugheadjones like this.
