If you've made a "custom" grill...like when using drawer knobs or something, what did you use as a backing?
your supposed to use expanded metal like http://www.yongshengwiremesh.com/welded-wire-mesh/wire-mesh-9.htm or the style that is slotted with little holes
Most used metal grating. Look at home depot over by the all thread, links of chain, and bulk cable. They usualy have sheets of metal cross grate in flat boxes. I'll try to find some pics of the stuff for better referance. I'm too slow abelugo got it
That's the mesh I used to make an insert for my old van. I brazed some bolts to the back of my grille, then slid the mesh over the bolts. This made it possible to easily remove the insert if needed. The knobs were also hardware store items.
