Custom Paint Question
Discussion in 'The Hokey Ass Message Board' started by El Caballo, Feb 6, 2012.
  1. El Caballo
    El Caballo
    from Houston TX
    I’m working on ideas for paint for the roof of my ’58 Chevy. I want to put lace on it and some air-brush details like the one pictured. I’m mostly intrigued by what borders the lace in the picture and how this effect is done; does anyone know how it was done?
    Thanks R&C
  2. SinisterCustom
    SinisterCustom
    Take a piece of poster board and cut it out like a "blob".....or "splash"....and just use it as a stencil, moving it around at various angles.....spraying yer candy....
  3. El Caballo
    El Caballo
    from Houston TX
    Hmm, looks like you would need to be real careful with that. If you look at the picture up close you can see where the template has been moved quite a bit. Either that or he used multiple templates.
  4. big creep
    big creep
    ancient chinese secret!;)
  5. chopolds
    chopolds
    from howell, nj
    Sinister's got it. You can do it very quickly with a template, and yes, move it around, overlap each other, use different shapes.
    Only thing I have to add is I like to use the paper you buy to print photos on. It holds up better than paper, with cleaner edges.
    Back in the day, my boss had ones cut out of sheet metal, with a welding wire brazed to it, for a handle. For doing fish scales, and blobs like your pic.
  6. El Caballo
    El Caballo
    from Houston TX
    This may sound silly but would you use a regular paint gun or an air brush? It would seem that for details like that an air brush would be best because there would be less paint loss and over spray.
  7. Gary in da UP
    Gary in da UP
    Did you consider just doing a "test" panel?
  8. El Caballo
    El Caballo
    from Houston TX
    Geography is a *****, the car and all my tools are in Texas and I am in Australia.
  9. BigNick1959
    BigNick1959
    They cut out a form and used the positive and the negative of the template. Less is more with that kind of thing, it's easy to over due it and lose the affect.
  10. El Caballo
    El Caballo
    from Houston TX
    Yep, you either have an eye for that or you don't.
    So what would you use Nick, gun or air brush?
    Thanks Tman!
  11. afaulk
    afaulk
    A small touch-up gun works good and covers larger areas lots faster than an airbrush. Looks like stuff i was doing in 1972 LOL.
  12. El Caballo
    El Caballo
    from Houston TX
    Everything old is new again. Thanks for the tip.
  13. SinisterCustom
    SinisterCustom
    I'd use an airbrush on a panel that small......and if ya use intercoat for the candy, it'll dry quickly and there will be no issue of the paint "smudging" on yer stencil when overlapping.
  14. El Caballo
    El Caballo
    from Houston TX
    Could you explain what intercoat is?
  15. SinisterCustom
    SinisterCustom
    It's a clear basecoat......you can add yer candy intensifier to it, pearl, metalflake or even add it to a base color to make it more transparent..or to blend....
  16. El Caballo
    El Caballo
    from Houston TX
    I've got a lot to learn, thanks for the help.
