Technical Custom Paint with Cobwebbing.
Discussion in 'Traditional Customs' started by Bob Marshall, Jan 28, 2022.
  1. Bob Marshall
    Bob Marshall
    Anyone remember the cobwebbing on custom paint? If you were to try to duplicate that today, what kind of paint would work? I believe it used to be done with unthinned laquer which is not available any longer. Trying to touch up a 50 year old custom paint job on an old Corvette.
  2. RMR&C
    RMR&C
    from NW Montana
    Yeah, lacquer is what you need...modern paints won't work. At least none I've tried.
    What color do you need and how much? I still have some misc lacquer leftovers.
  3. chopolds
    chopolds
    from howell, nj
    I've experimented with trying to get a cobweb effect with modern paints. Not so easy! I finally came up with something that's close, but not perfect.
    Using basecoat paint, in a siphon gun (gravity won't work at all), not reduced, and low pressure. I Tee'd into the air line right before the gun, put a small regulator there, and fed it into the top of the siphon (I used one with a threaded hole for the air inlet) Playing around with the pressure going into the gun's reservoir, I could get an approximation of the old cobwebbing. I didn't attempt to refine the effect, as I was just painting the pool table. But you might get a better webbing if you play around with it. pooltable.JPG
  4. Wow, a scalloped pool table! It doesn't get much cooler than that! E
  5. K13
    K13
    OG lil E and hrm2k like this.
  6. guthriesmith
    guthriesmith
    I know I have done it on accident when I was trying for the granite look with newer base coats, but not sure I have ever tried to do it on purpose. My method for ending up with it on accident was basically similar to chopolds, but I could have sworn I was using a gravity fed gun. I do like the look on the right paint job. Good information to have. Curious what others say.
    chryslerfan55 and OG lil E like this.
  7. 64coolbrez
    64coolbrez
    from Dover pa.
    K13's right get the acrylic lacquer fron TCP GLOBAL. Get your self a #7 binks old *** gun, then don't thin the paint the thicker the better.the lower the air the longer the strands. I loved cobwebbing .if the paint is too thin let it set with the lid off. Go off an on with the trigger. Get the air, paint, n distance right you'll match it. Have fun. Ps thanks for the memories.
  8. Rand Man
    Rand Man
    I love old paint techniques. Don’t know how to do it myself.
    guthriesmith likes this.
  9. Gahrajmahal
    Gahrajmahal
    With the siphon gun and the un-thinned lacquer turn the air pressure down. Your distance from the panel is 12” or more. You move pretty slow. After drying cover with your clear of choice.
    chryslerfan55 and guthriesmith like this.
  10. Bob Marshall
    Bob Marshall
    Thanks for all the good info. Will try TCP Global.
  11. Max Gearhead
    Max Gearhead
    from Wisconsin
  12. COCONUTS
    COCONUTS
    Starting with the base coat spray on with slow drying reducer then go with un-thin lacquer out of a Binks gun with the standard production nozzle. It will come out all stringy, to be covered with clear lacquer with a slow drying thinner. Oh yea, don't forget to pick a base color that will offset the cob-webs.
  13. Torchie
    Torchie
    You can also get small cans of Lacquer from guitar restoration supply companies.
    I put cob webbing on my 56 Merc 2 door hardtop back in the 70's
    It was inside the trim that went under the side windows on a Montclair. Car was black and I cob webbed it with gold metallic.
    Lacquer straight out of the gun with no thinning. Took a while to dry but it was fine once dry.
    Torchie
  14. K13
    K13
    Most guitar restoration places like Stewart Mac seem to be selling ready to spray pre thinned stuff these days.
