Hot Rods Custom tie-rod
Discussion in 'The Hokey Ass Message Board' started by woodiewagon46, Jan 2, 2023.
  1. woodiewagon46
    woodiewagon46
    from New York
    Anyone know a company that makes custom length tie rods. I need one 30 and 1/4" with RH and LH, 11/16"-18 threads.
  2. TCTND
    TCTND
    Speedway
    irishsteve likes this.
  3. sdluck
    sdluck
    Can you weld,they make ends that can be welded to tubing.
    2OLD2FAST likes this.
  4. krylon32
    krylon32
    from Nebraska
    I get all mine made at Roadster Supply in CA. Quick service and reasonably priced.
  5. krgdowdall
    krgdowdall
    from Alberta
    Look into Paul Horton Welder Series. welderseries.com
    They stock a variety of sizes and will custom build one for you, if they don't have the size you need.
    Good people to deal with.
    You can get a longer rod and cut it down. Cut the right hand end, the tap is cheaper than the LH tap if you need to purchase one.
  6. 1971BB427
    1971BB427
    from Oregon
    I build my own by buying weld bungs in RH-LH, and it's way cheaper and easy to make. Better quality than most you buy also.
