Technical Custom wheels
Discussion in 'Traditional Hot Rods' started by Kerry Phelps, Oct 18, 2025.
  1. Kerry Phelps
    Kerry Phelps
    Probably been asked a million times but I'm a newby on here. Looking for suggestions for custom wheels (Cragars, etc.) that will clear the rear axle hub on a 37 Ford.
    LOU WELLS likes this.
  2. alchemy
    alchemy
    Only late model stock car wheels. Unless you can locate some vintage Safety Racing stock car wheels.
    We call those “wide fives” and no company ever made street car wheels for them. But the same bolt pattern has been used in the racing industry since way back then.
    2devilles and Squablow like this.
  3. alchemy
    alchemy
    Edit: I think Johnson’s Hot Rods now makes wheels for these hubs. Probably all CNC from aluminum. Contact them, but I’d bet you should be sitting down when asking the price.
    Happydaze likes this.
  4. Kerry Phelps
    Kerry Phelps
    Thanks!
  5. Kerry Phelps
    Kerry Phelps
    Thanks!
  6. tubman
    tubman
    I'm wondering if he still has "wide-fives" on his car, since he asked about rear axle clearance and not the weird bolt pattern. A lot have been changed to 5-5 1/2" in the las 85 years. It then becomes a different problem but opens up the choices a lot.
    We need to know the real problem first.
  7. RodStRace
    RodStRace
  8. alchemy
    alchemy
    I guess I ***umed he knew what he had. But it’s very common to find out after we provide advice that the OP has something totally different.
    Just Gary likes this.
  9. LOU WELLS
    LOU WELLS
    from IDAHO
    His 1937 Coupe Has 1940-48 Brakes And 5.5 Bolt Circle...As I Recall...
  10. alchemy
    alchemy
    Ha, foiled again! I guess if he never comes back, he’ll only have himself to blame.
  11. Kerry Phelps
    Kerry Phelps
    Sorry.... been away for a few days. Lou is right. Hubs and drums are 5X5.5 Was just wondering if wheels like Cragar are deep enough in the center cap area to clear the end of the axle.
  12. Crocodile
    Crocodile
    I have the new production American Racing Torq Thrust Originals on my 40 with the stock rear end and it does not have any interference with the axle stubs.
    I would think most center caps for aluminum slots should clear too.
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
  14. Kerry Phelps
    Kerry Phelps
    Thanks, I'll check them out.
  15. Kerry Phelps
    Kerry Phelps
    Crocodile....I took your advice and bought the American Racing Torque Thrust originals and they fit great! Thanks
  16. Crocodile
    Crocodile
    Glad it worked out for you, too! They are one of the more "correct" looking wheels for being a modern production too, so they look great on our old Fords.
    Kerry Phelps and LOU WELLS like this.
