### Customized 50's and 60's Tonka Trucks ###
Discussion in 'The Antiquated' started by A Boner, Dec 31, 2018.
  1. A Boner
    A Boner
    image.jpeg Drill 2 new front axle holes.....end up with a cool California Rake!
    Spooky, VANDENPLAS, Okie Pete and 7 others like this.
  2. RidingMechanic
    RidingMechanic
    from Cincinnati
    ya know, that's not a bad idea...I ended up with a truckload of not-very-valuable Tonka and Structo trucks. Would be interesting to test out some custom body work or paint on 'em.
    As a kid I had a similar Wrecker, but it was the slightly later 68-72 GMC style. I wanted to repaint it and replace the broken plastic headlights...got as far as taking it apart and stripping down to bare metal. 30 years later I found it in a paper bag when cleaning out Mom's attic.
    Even back then I could never finish a project!!
    pigIRON63 likes this.
  3. Rolleiflex
    Rolleiflex
    I've got that same truck that someone painted the whole thing green, tires and all. It'd be a perfect candidate for dropping.
    I've found a few online part sources for Tonka vehicles. I haven't ordered from any of them yet though and would love to hear which ones are great to deal with.
    Here's just one I've looked at: https://www.toydecals.com/tonka_parts.htm
  4. A Boner
    A Boner
    image.jpeg I would think if a parts supplier is on Ebay with a good rating, they should be ok.
    If you are missing hubcaps, I made moon disks using the bottoms of aluminum soda cans.
    The blackwall wheel hubcaps pry out of the rubber tires (soak in warm water). With the whitewalls, you have to carefully pry the whitewall out of the tire to remove the hubcap.
    Spooky, Okie Pete, pigIRON63 and 8 others like this.
  5. I like to customize (play with ) the rough ones Too. Here's two Roadster pickups I did. Ron... 20190103_182404.jpeg 20190103_181953.jpeg 20190103_182259.jpeg 20190103_182217.jpeg
    Sent from my SM-G920P using The H.A.M.B. mobile app
  6. joncrane
    joncrane
    There was a Tonka truck kit to add a steam engine. I have been looking for one for years.
  7. A Boner
    A Boner
    ^^^^^ Looks good.....all it needs is 2 axle holes drilled to give it the California rake!
  8. CaptainComet
    CaptainComet
    I have restored a bunch of first generation Hot Wheels. I have found that you may get lucky with kiddie painted items by simply dropping them in water for a day or so. Sometimes that extra paint will float off because it is rare that a kid would do actual surface prep. Best of luck with it!
  9. johnnyknox
    johnnyknox
    from illinois
  10. johnnyknox
    johnnyknox
    from illinois
  11. Ohlly
    Ohlly
    Nylint Jungle Wagon
  12. A Boner
    A Boner
  13. noboD
    noboD
    Tonka?? Is nothing sacred on the HAMB?
  14. A Boner
    A Boner
    Another red and white Tonka Pickup…lowered+Wisconsin style patina.
  15. A Boner
    A Boner
    Borrowed pic off Facebook group…Tonka Rod & Customs
  16. A Boner
    A Boner
    Latest custom TONKA. Short box conversion…I shortened the wheelbase and moved the rear fenders ahead 9/16”…also moved the axle holes up to lower it!
    Spooky, Rolleiflex, Lepus and 2 others like this.
