Projects Customizing a stamped steel valve cover...
Discussion in 'The Hokey Ass Message Board' started by Kevin Hadder, Dec 7, 2016.
  1. Kevin Hadder
    Kevin Hadder
    Hi... new here...
    I saw a few threads on this topic, but couldn't seem to find anyone who has actually done this -
    Would it work to take some custom steel strips, cutouts, or letters and glue them to a valve cover with JB weld, then give it a nice paint job? I'm thinking it could make for a nice custom valve cover with raised detail. Would JB weld hold up?
    Thoughts?
    Kevin
  2. Yea that works, usually looks pretty hokey but it works.
    Better idea is pin stripes or hand painted letters.
  3. Tim
    Tim
    from KCMO
    I've never seen it done but I suppose it's as straight forward as it sounds.
    Last set of something similar I saw they had made a female die for the lettering and hand stamped the words into a piece of sheet metal before cutting the old top out of the valve cover and welding in the new one.
    I'd suspect between heat and vibration the jb weld would fail but I've never had that great of luck with it in the first place
  4. 38Chevy454
    38Chevy454
    I would weld the metal rather than glue. But I agree that some nice hand painted lettering or a real stamped insert would look better.
  5. nochop
    nochop
    from norcal
    Just don't make fake Rocket covers ;-)
    X38 and flynbrian48 like this.
  6. I remember a guy here did some Hemi valve covers.
    Just don't remember what the thread was.
    Anyone know?
    Johnboy34 likes this.
  7. Rusty O'Toole
    Rusty O'Toole
    I have thought of making fake cast aluminum valve covers by covering a steel one with bondo or fibregl***, sticking aluminum strips or some kind of emblem in the top, sanding or sculpting to taste then paint the valve cover with aluminum paint or maybe flat black, and polish the strips or emblem. Never got around to trying it. No reason you can't sculpture any shape or design you want in bondo or fibregl*** and it should last if it is painted and you don't knock it around.
  8. Johnboy34
    Johnboy34
    from Seattle,Wa
    kiwijeff likes this.
  9. ^^^ Thats the one.
  10. Shot off ones off my blown 400 sbc...did doubly trim on vinyl graphic that I made then pulled out only the Shadow and gl*** beaded it while the rest was still covered 20161210_180316.jpg
    mad mikey likes this.
  11. bobbytnm
    bobbytnm
    Anything is possible. On my 500ci Caddy I tool some early 50's Caddy valve covers, cut the tops off and then welded them onto my existing stamped steel covers. After a little bit of paint they look pretty good;
    low budget, clunker and kiwijeff like this.
  12. Come on man!!
    Cut and weld your own valve covers. :D
  13. dumprat
    dumprat
    from b.c.
    I have a truly perverts need to make some that look like they are fabricated out of old wooden barn boards.
