Cut coils and 2-2 1/2" drop uprights ??
Discussion in 'The Hokey Ass Message Board' started by Jimmyz, Mar 13, 2006.
  1. Jimmyz
    Jimmyz
    This anybody running as set of 2-2 1/2" drop (spindles, upright, or whatever they call them) and cut coil springs?
    I'm getting ready to install some of the uprights on my 51 Chevy 2dr. Duluxe and I already have cut coils. How low do you think I'm going to go?:D
  2. Just Gary
    Just Gary
    If you haven't dis***embled the frontend already, take a look at the distance from one compressed coil to the next. Also look at how much clearance you have between the lower A-arms and the bump-stops.
    I installed a set of Heidt's 2" dropped spindles on my '55 Chevy, then brought it down even more by cutting the coils with a cut-off wheel (never use heat!)...
    With the first set of coil springs, I made the mistake of starting out by removing two complete wraps, which was way too much. The lower A-arms rode on the bump-stops-- the front suspension was essentially solid.
    I then got another pair of coil springs and "snuck up" on the best ride height by cutting a half-wrap at a time, then installing them and checking the profile. As it turned out, 1.5 coils was the lowest I could get, while still retaining some semblance of a ride. It brought the front end down an additional ~2", for a total of ~4". :)
    Be sure to get the front end realigned after dropping the car.
    Hope this helps.
  3. Rhino
    Rhino
    from ST. Louis
    What kind of uprights, stock,what year, aftermarket?
  4. kropduster
    kropduster
    breeders 53 is minus 1 full turn and dropped uprights, rides pretty good and sits nice too.
  5. breeder
    breeder
    no im not!!! i just let air out of the tires!!:D wished id done 2 turns but it was a pain in the **** to begin with.. could of been the whole puttin them on upside down the first time and havin to do it all over again..IF YOU ARE A DRINKER,,DONT AVER GIVE IT UP!!!!:D turns ya into me:confused: :p dont forget your lowered steering arms...national chevy has all ya need...hope your check books think.:eek: :D breeder:)
