Technical cut or chem alter rust on floor brace?
Discussion in 'The Hokey Ass Message Board' started by 1930artdeco, Nov 18, 2023.
  1. 1930artdeco
    1930artdeco
    from Lynden, Wa
    OK, I am looking at the front floor brace on my 57 Ford wagon here. I am going to try and blast and then chem alter and seal the rust. BUT, there is cancer forming I know but am I good to forward with my plan? Or do I need to replace the brace?
    Thanks,
    Mike
  2. CSPIDY
    CSPIDY
    It really depends on your build
    but
    to me it doesn’t look too bad and should be ok
    for pits
    rule of thumb is 10% or less of total thickness of depth is acceptable
    ekimneirbo likes this.
  3. evintho
    evintho
    I see some deep pits and looks like it's all covered by that factory undercoat garbage. What's the other side of that brace look like? Also, how bad is the end that tacks to the inner rocker? Mine was pretty messed up....
  4. 19Eddy30
    19Eddy30
    from VA
    Seal it & use,,,
  5. 1930artdeco
    1930artdeco
    from Lynden, Wa
    The attachment is solid and bottom of the brace is covered in desert concrete. That is what is saving the body I think.
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
    IMG_2302.jpeg seem’s to be the concern.
    Personally I’d use it.
  7. bill gruendeman
    bill gruendeman
    Blast it then epoxy it, I think the pitting is from being full dirt and holding moisture. Shouldn’t be a problem on a car that sees limited use in mostly dry weather.
  8. 1930artdeco
    1930artdeco
    from Lynden, Wa
    Thank you all for your opinions. I will get some new media and blast away. Then use a converter and epoxy paint it.
  9. 1930artdeco
    1930artdeco
    from Lynden, Wa
    Well……..the HF blast was ****-I was hoping it might work but it just peed material out. I might have done something wrong so I will try again one more time before I s**** it. So I ended up using Ch***is Saver rust converter and sealer. I will add a few more coats and then start cutting down the floor pans this weekend.
  10. alanp561
    alanp561
    Have you tried Citric Acid? There are several threads on here suggesting its use. I've used it and it works well.
