Technical Cutting Battery Cable
Discussion in 'The Hokey Ass Message Board' started by 5window, Nov 12, 2025.
  1. swade41
    swade41
    from Buffalo,NY
    Did you buy the cable ends and solder pellets from batterycableUSA too ? I did and they all worked great, they didn't offer one of the sizes I needed and was another reason I bought that crimper cutter set, which also did a great job.
  2. 1biggun
    1biggun
    I use cable cutters .
    I use them to cut a ring around the coating and pull that off I then cut a second thin ring and pull it down to the very end but not off. That keeps the copper strands together and tight so the crimp or solder in cable end goes on with out frying the strands once its on I cut the thin ring away.
    I use crimped that you hit with a hammer and shrink tube over that.
    Thats how I do hundreds of cables a year for electric forklifts and automotive.
    Some ends require solder. Be sure you use rosin core solder. DO NOT USE ACID CORE
  3. 1biggun
    1biggun
    These type of crimpers work well with a 3lb hammer.
    Don't forget to put the shrink tube on first.
  4. dwollam
    dwollam
    @swade41 , I ordered that set after your recommendation. Should be here in 3 days.
    Thanks!
    Dave
    swade41 likes this.
  5. 5window
    5window
    No, I had lugs crimped on one end and hope to use these on the ends I cut to length. upload_2025-11-18_12-12-7.jpeg
    swade41 likes this.
  6. 5window
    5window
    Did you cut the insulation first then use the cuter for the copper?
