Technical Cutting coil springs / or spring spacers?
Discussion in 'The Hokey Ass Message Board' started by evil clown, May 23, 2022.
  1. evil clown
    evil clown
    from Verona, WI
    I have a’56 Buick Special that sits crooked. The drivers side sits exactly 1” lower than the p***enger side, in front & back. This is after putting all new stock height springs in.
    Will cutting the coils only on the p***enger side (to even her up) cause poor ride characteristics?
    Would putting spring spacers in on the drivers side (to even her up) be better?
    Is there something else in the suspension that could cause this?
    I’m stumped! Thanks in advance for any help!
  2. BamaMav
    BamaMav
    from Berry, AL
    How long has it been since you put the new springs in? They need time to settle. Drive it around for a week or two, then see how level it is. Then you can decide on surgery or not...
  3. evil clown
    evil clown
    from Verona, WI
    That’s a good point, they are fresh springs, with almost no miles on them.
    But “the rest of the story” is that it was about 1 & 1/2” out of level before putting in the new springs. That’s why I replaced the springs to begin with.
  4. twenty8
    twenty8
    The springs may not be the problem. Swap them over (left to right, right to left) and see if it makes any difference to the side the car leans. It might be a bent ch***is or bent suspension components.
    I would not recommend cutting the coil on only one side. The cut spring will be stiffer, and may cause handling issues.
    If the leaning has only happened after fitting the new springs, check the installation. Make sure they are seated properly, and let them settle.
    41rodderz and VANDENPLAS like this.
  5. evil clown
    evil clown
    from Verona, WI
    Thanks for your thoughts, that’s why I’m asking. I’m just having trouble diagnosing what could cause the “lean” both front and rear. Body mounts could be another suspect I suppose?
    VANDENPLAS likes this.
  6. twenty8
    twenty8
    Gas tank and battery are both over towards the driver's side???
    Fill the tank, get someone to sit in the driver's seat, and have a look.
    Sometimes the manufacturers built in some compensation from the factory.......
  7. 41rodderz
    41rodderz
    from Oregon
    Is the tire size , series and air pressure the same ?
    twenty8 likes this.
  8. NoelC
    NoelC
    The first thing you think about when someone says saggy **** is it needs a new lift, aka springs. But saggy dried cracked and crushed body mounts are usually the problem... Those however are a lot more work to replace.
  9. Motorwrxs
    Motorwrxs
    Seems like Frieburger had an issue like this on Roadkill Garage…springs were same height but had different spring tension?
