Cutting flutted holes in visor
Discussion in 'The Hokey Ass Message Board' started by Vintage Driveline, Sep 19, 2006.
  1. Vintage Driveline
    Vintage Driveline
    Alliance Vendor
    How do you cut the flutted holes in the Model A visor?
    They looks awesome!!!!
    Cheers !
    Jay
  2. By fluted, do you mean flared, like the holes in aircraft bracketry? Probably use a punch with the contour built in. Does any body know where do get these?
  3. old beet
    old beet
    Mittler Bros has them, they work on a louver press.......OLDBEET
  4. 1Bad67
    1Bad67
  5. If you have access to a lathe you could make a larger scale tool similar to this one.
    Cut out the hole with a GreenLee punch or similar then flare.
    This one is used to flare sheet metal for Dzus buttons.
    1" OD 6061 T6 aluminum, 3/8" bolt & nut.
    Cut the flare/countersink with a standard 82 degree countersink.
    Leave a ledge as a stop.
    Aluminum would probably work ok for a tool that's not used too often, but steel may be better.
    The aluminum Dzus tool pictured is hanging in there pretty well after having flared quite a few holes.
    You can make this with a drill press and hacksaw along with a little determination.
    A stainless bolt and nut are shown, but they tend to gall after a while.
    A black oxide bolt and nut are better and standard Cad-Iridited bolts and nuts work well.
    A small drop of lube on the threads helps the black oxide stuff and the Cad stuff, but the stainless still tends to gall.
  6. I've heard them called "lightening holes" and you can make them with a "dimple die" or a "punch & flare tool".
    Here are two sources:
    www.vansantent.com
    www.kartek.com
  7. buschandbusch2
    buschandbusch2
    from Reno, NV
    Also, Ron Fournier's "Metal Fabricator's Handbook"(?) has info on turning dimpling dies on a lathe.
  8. screwtheman
    screwtheman
    Good info, fellers! Here's another good link I found when browsing those other ones:
    How flared holes are made
    Kinda reminds me of the stuff I found when I was researching homemade velocity stacks.
  9. Here's the prices:
    Flare Hole Die Prices
    Part #
    Size
    Price
    15835
    .75"
    29.95
    15840
    1.0"
    39.95
    15850
    1.5"
    69.95
    15860
    2.0"
    99.95
    15865
    2.5"
    109.95
    15870
    3.0"
    179.95
    15875
    3.5"
    219.95
    15880
    4.0"
    269.95
    15885
    5.0"
    349.95
    15890
    6.0"
    429.95
    Sets
    15810 .75"-2.5"
    5pc.
    314.79
    15815 3", 3.5", 4"
    3pc.
    602.86
  10. Vintage Driveline
    Vintage Driveline
    Alliance Vendor
    great info guys!!
    Jay
  11. Da Tinman
    Da Tinman
    MB has em that are a punch flare combo,, will do both operations at once. They have a 1/2" bolt that sqeezes them together, on need for a press.
    Will do up to 16 ga steel. The one that is 2" diameter flares to just over 2 1/16" makes nifty gauge hole in the dash, punch them in and the guages are sunk in,, punch out and well ya get the point. :D
    I'll try to get picture in the AM if interested
  12. man-a-fre
    man-a-fre
  13. Clyde
    Clyde
    from Las Vegas
    The tool is called a Belling-Tool, they are easy to make on a lathe. A friend of mine has built himself a full set of them in .25" incerments from .75" up to 3". They work great on sheet metal up to 18 gauge and Aluminum up to 1/8". For steel over 18 gauge a Belling-Tool in a press is needed.
