cutting front coils spring
Discussion in 'The Hokey Ass Message Board' started by BLUDICE, Oct 2, 2010.
  1. BLUDICE
    BLUDICE
    A little shoebox help here please. I know this won't be exact, but when cutting coils to lower a car, how much does 1 cut coil equal, in inches.
  2. squirrel
    The first coil doesn't do as much as the second...the first should give you a couple inches, then each 1/2 of a coil after that will also give you a couple inches. So sneak up on it, don't try for the whole drop on the first go, or you might be buying new springs. Also let it settle, drive for a week or so after the first cut, before you decide it needs more.
  3. jonnyonedrip
    jonnyonedrip
    from canada
    if you cut a full rung you usually have to pull the spring out to get out the piece. if you cut halves usually you can fish the pieces out if you use a spring compressor just to take the tension off i have had good luck with just torching the pieces off but a cut off wheel works great too its a yucky job but the results are awsome. remember its not low enough unless something is draggin.
  4. temper_mental
    temper_mental
    from Texas
    Remember after you put the coils back in the car the car will lower more over time. I never used a torch I always took the spring out and cut it with a cut off wheel. Good luck
  5. 8FLEET9
    8FLEET9
    from MASS.
    don't cut more than a coil outta that car. the lower control arm will get in to the bumpstop mount hard real quick. you'd be much better off modifying the lower control arm spring pocket to lower it.
  6. canman
    canman
    Cutting the spring also increases the spring rate. Handling may be effected differently than you wish.
  7. squirrel
    Increasing the spring rate, at the same time you decrease travel, is generally a good thing.
  8. KrisKustomPaint
    KrisKustomPaint
    there is nothing wrong with cutting it with a torch. you'll only affect the temper in the first inch next to the cut. Its a whole helluva lot faster too, especially if your "sneaking up on it". 30 seconds a cut versus 2 min a cut doesn't sound like much until you do it 4 times per coil.
  9. canman
    canman
    Depends. It could prevent bottoming which as you say would be a benefit. It will increase ride stiffness and that may not be a good thing. It will also change the roll couple and if the car is not just a cruiser but a performance car that may not be good.
  10. Russco
    Russco
    from Central IL
    Depending on how low you are wanting to go I'd say at least 1 full coil to start with then maybe more. Here is a stock spring that has been sagged with a torch compared to an Aerostar spring right out of the box the Aroestar spring drop about 2 1/2 inches
  11. vintagehotrods
    vintagehotrods
    Why not just spend a $100 and buy the shorter coils that will give you the proper spring rate and drop you need. Otherwise if you want to do it cheap, just heat the coils with a torch to get your drop.
  12. It is illegal to use cut or heat drop springs here in NZ.
    Your car will be immediately put off the road
    or confi****ed.
  13. KrisKustomPaint
    KrisKustomPaint
    Sagging springs with a torch is about the dumbest thing ever, but i don't get why its illegal to cut em with a torch. A lot of people shy away for a torch because they don't have a clue how to use them, then they F something up and blame the torch.
  14. Mudslinger
    Mudslinger
    I cut one and a half coils off my 49 springs years ago. The only time I ever noticed anything was in a turn doing about 25 mph coming down a hill. I made the left and felt a bump on the snubber on the far side. No trouble with bump steer etc. I had the original springs but they were in really good shape. I think when you take two coils off your getting into the problem area.
    I forgot I have a good side shot of my 49 in my album. Its running 205/75R 15"
  15. Our very informed officials from Govt see one or two bad examples of a job badly done then they set laws in place to punish "Everybody" :mad:
    Doesn't that happen over there?
  16. canman
    canman
    Yes but usually a politicians brother or some family member has to be in the business that benefits. Of course it could just be they themselves that benefits also
  17. Johnny1290
    Johnny1290
    You can't just start with some $60 aerostar springs and see how you like them?
  18. fathead429
    fathead429
    from Yuma, AZ
    When I had springs in my coupe...I cut 1 1/2 coils out of brand new 50 ford springs with no problems...unless I tried to go all "dukes of hazzard" in my coupe. Probably wouldnt go 1 1/2 out of old springs though with all the sag from wear and tear from the last 60 years. If I had to do it over again, would definatly go with the aeorstarts as a start. Cant beat the price.
  19. lincolnlog
    lincolnlog
    from Arizona
    I have some of these*new* that I would sell, that didn't hold up the the m***ive weight of the lincoln!! bumpstops!:eek:
