Cutting glass-Tech O' Matic? RYAN?
Discussion in 'The Hokey Ass Message Board' started by lulabelle, Nov 27, 2003.
  1. lulabelle
    lulabelle
    There have been alot of posts lately on cutting curved gl***.I didn't see anything in the T.O.M.on the subject.I'll start with how I did it on my 51 Chev...I lay the gl*** on a piece of foam so it has equal support.I then use a grinder with a THIN cut-off wheel.Make a light p*** along the line to score it.Spray it with WD-40 or whatever spray lube you have around.Keep making light p***es while keeping it lubed.Eventually you'll be through the piece.Take your time!I didn't make the sharp corner cuts at first.Just took it off a little at a time.After you have it cut as close as you can,take it to a gl*** shop to have the edges "polished"(sanded).I know there are others who are way more qualified than myself on this subject.Lets hear how you have done it so we can put together a good T.O.M.I hope this helps.
  2. That sounds Good Lulabelle- I am open to any way that makes it happen. I feel like a lot of people need this info so lets all kick i our bits of info we have aquired from the school of hard knocks....My offering to this subject is the result of in progress experiments with cutting curved and flat "Duoplate"/safety gl***[not tempered] for cars that have been chopped.I am suggesting cutting the gl*** or windshield with a WET TILE SAW- [whether rented or purchase][cheaper]and a 7"diamond coated blade. one would need a second set of hands for my method for sure. I have cut lots of experimental peices and am confident this IS a do-able method that most anyone can master. I had good results the FIRST TIME-so I feel that its possible for a good result the first try.it would help if a person was spraying the cut with a sruit bottle[not a hose dummy!]the saw has a tray that holds water -but it could run dry on a long cut- it must be steadied as it is moved thru the cut and if twisted much it would crack. also one might be smart to tape some straps across the curved w/shield to keep each peice from spreading or moving-possibly a light weight "buck'could be glued or duct taped to gl*** to support it. also like Lulabelle said above- make only straight cuts as close to your cut line as possible-"squaring off" the corners untill you are close enuf to line all the way across that it could then be belt sanded till perfect.the windshield would have to be tilted and eased across the stationary tile saw using the two man method to succeed-key word here is [NO SUDDEN MOVES] kinda handle it like it was nitro glycerin and you should be all rite. THIS WOULD BE THE CHEAPEST AND FASTEST METHOD I HAVE ENCOUNTERED.
  3. lulabelle
    lulabelle
    Thanks choprods.As he said.Many have tried to cut tempered gl*** with no luck.
    I also cut the gl*** before the car.That way I was sure I wouldn't be stuck.Build the car around the gl***!Also,after I scored the gl*** I removed the tape line so I could watch the gl*** as I cut.
  4. Yeah....maybey use 1/8"striping tape to mark the cut-as a marker would wash off.
  5. flt-blk
    flt-blk
    from IL
    [ QUOTE ]
    [/ QUOTE ]
    That sounds like an important tip.
    TZ
  6. Blownolds
    Blownolds
    from So Cal
    How about trying those thin diamond wheels that Dremel/Foredom tools use? That would probably be the thinnest "cut-off" wheel you could get, and the smaller diameter means you are cutting in a shorter "patch" than a larger diameter wheel (that would have a longer active cut-line going). That might also then help keep the "little at a time" method easier to accomplish and less chance of ****ing the wheel in the groove and binding it up. Anyone ever tried that?
    I also have heard of gl*** shops simply sanding the entire piece down using a belt sander that is continuously flooded with coolant. That seems like it might be hard to see the cut line though.
  7. lulabelle
    lulabelle
    I've tried the dremel idea.It doesn't work verry well.Slllooooowwwww.And as for the polisher,you better have alot of belts and a patient gl*** shop!
  8. 286merc
    286merc
    from Pelham, NH
    Ive heard mention of sandblasting also. I wonder if one of those small "air spot sandblasters" that are sold for crafts work are any good. Cant imagine using my TP-99 pressure job on gl***.
    Good alert about cutting the gl*** first! I remember a few HAMBer chops that wound up getting sold off minus the gl***!
  9. BTTP-How about it Olcargl***guy or Scarliner- anyone else,add to this to make it a valuable reference?
  10. ive been studying all the gl*** cutting posts because im gonna be trying it probably around spring time.im gonna try the lulabelle method bacause its seems controllable.i keep having this nightmare about a wet tile saw kicking back on me. [​IMG]
  11. The only caveat I can add to this is:Wear a GOOD respirator while grinding as well as eye protection!Microscopic gl*** particles are NOT digestible and play havoc with your vision!Ask my wife who used to do a bunch of gl*** grinding and cutting in her stained-gl*** work.I'm sure Becca could attest to this.
  12. lulabelle
    lulabelle
    BTTT Anyone else?
  13. WZ JUNK
    WZ JUNK
    from Neosho, MO
    I use a small pressure feed sandblaster. I mask the windshield with 3 M double stick tape that is used to stick moldings on cars. I use the tape as a guide for the blasting tip and I just run the tip along the edge of the tape as I go across the gl***. Takes about 40 minuets to cut a large windshield. It will require sanding after cutting.
  14. 48_HEMI
    48_HEMI
    I went back to my old handle, but my business name is still "The Old Car Gl*** Guy"
    I've tried a few different methods. I think Peter has some spy shots of me cutting the windshilds on his Queen Mary HAMB CHOPPED Olds I think I spent about 15 minutes on each one.
    I have several hundred new old stock windshields in stock but I don't think I'll be practicing on them.
    I might try the wet tile saw just for kicks. look like fun [​IMG]
    all these methods work to some degree I've tried the cutting wheel method on compound windshield with zero success.
    something like a 54 chev you could almost scratch with a nail and break it right.
    some windshield are harder. these new windshield from south america I save about 1 in 10 while the ones from china I save about 9 of 10. the one made in the U.S.A. I don't think we even make them anymore. you see Speedy Bill is not the only company sending products off shore!
  15. Thanks for the input 48 Hemi- you should know.........I think the thing to remember about my proposal is that it has zero gl*** dust unlike sandblasting and it also would be a better success ratio for a beginner as the cut is cooled better all over the gl***- with water. I never heard of anyone getting shocked using one of these tile saws in a proper stationary position. -Every time I tried a cut off wheel [on gl***] It was throwing sparks, so unless you used water as a coolant the risk of setting your self on fire is something to consider.another point of interest on this method I used -is the peice of gl*** I showed in my post is still here on my computer desk about 3 months later/not even sanded on a belt either- and it has not hairline cracked at all. Considering that one of the cuts was in the middle of a curve and at a striking 90 degrees and stopped in a corner- I think that in itself shows that it is safer [crack wise] than some other ways used in the past. it also cuts it very quickly which is a benefit.
  16. CharlieLed
    CharlieLed
    The wife used to do stained gl*** and has a grinder that she used to fit the pieces of gl*** together. It's a flat table with a grinding wheel/cylinder sticking up through it. There's water in the base that keeps the grining wheel wet and cool. I have used this tool to grind notches in gl*** doors for hinges in stereo cabinets, I am sure it would work well for auto gl*** as well. It will get the edge smooth enough that you can sand it down with a little 600 grit wet-or-dry for a really nice edge.
  17. 48_HEMI
    48_HEMI
    Choprods
    one more thing that I'm reluctant to post. I use anti-freeze instead of water for coolant, but thats nasty stuff if it gets flung around but its thicker and cools better. I noticed that your cuts are flakey on the edges that is most likly from the heat [​IMG]
    those square corners could be cut at 45 degrees and then ground with a wet belt sander to a radius.
    the windshields that I have problems with other than the south american one are like 67-72 chev pick-up.I can cut them 6-7 inches but have lost many trying to shave off 2-3 inches [​IMG] but I still just use a gl*** cutter and some trickery to cut windshields. next time I cut one I'll post some pictures of my trickery! [​IMG]
  18. Thats right Hemi- I was using the blade they sent with the 34 dollar saw- Im sure there is a better quality blade than that one! it does leave little "chips" along the cut but I figure they could be belt sanded on a real job. come on guys add your gl*** cuttin'-secrets to Lulabelles post!
  19. old beet
    old beet
    48 HEMI we must think the same. I also use the old fashoned method for cutting gl***, a gl*** cutter? I could grind every one with no breakage but need to change belts ever 3 minutes. Have done a few 55 Chevs this way. But with the cost of grinding belts, can't afford to do it. Also had many problems with 68-72 Chev pickups (them godamn sharp ears). Sandblasting seems to work fairly well, but have seen some breakage. The hand held gl*** saw is a **** shoot, one wiggle and its all over. Also can't stress enough, CUT A WINDSHIELD FIRST, just use a junk one so you KNOW the gl*** will fit. And never buy a chopped curved gl*** project car without an installed windshield. And NO!! there is "NO GAURENTEE"(sp) cutting curved gl***. I've cut a couple hundred in the last 30 years, still don't like to do it. Cut the first 35 perfect, then broke 7 in a row. Wish I knew a sure way, but some times "they just break"........OLDBEET
  20. 48_HEMI
    48_HEMI
    Beet your a better gl***man than me I only got 19 cut before I groke my first. I guess I was getting ****y and careless. Had a NASCAR guy from out of state that came in to the shop and wanted the bottom 5 inches cut off a new windshield I did it while he waited then he bought 10 more and asked if I thought I could get at least 5 and I sent him back home with all 11.
    that kind of stuff doesn't make me good. because its has more to do with the windshield and manufacture. many windshields are prestressed when they are laminated. when you relieve one side whether you use a cutter, sand or any other method the good side cracks. thats what has me thinking the tile cutter going thru both sides might have merit.
    I plan on retireing my business next year and am not sure I want to learn any more tricks that are related to the job [​IMG]
  21. a point that could be made at this time is your chop job could be major stubler in fitting a windshield.I thgink any time you widen the top you are risking an impossible fit so any time you are narrowing the width at top its better than widening there.[unless you can figure a way to add gl*** to its width!] [​IMG]
  22. old beet
    old beet
    48 HEMI, funny you say retire, got a letter from the union Saturday, they say I can retire anytime. Gonna take it 3 more years or die tryin. Waitin on the wife, 15 years my junior. Rite, old dog new tricks, can't even use my cell phone correctly..........OLDBEET
  23. scarliner
    scarliner
    from Macon Mo.
    Lulabelle, I am really kinda of a new kid on the block when it comes to gl***, I have been doing it about 5 years now.I probably broke somewhere in the ten gazillion dollar figure of new and used gl***.Ive broken enough mirror,to give everyone on the north american continent,7 years bad luck! But there has been a few good things come of this.I think any of these guys that have posted here,can tell you,theres nothing like experience.Even if its bad, if you learn something from it,thats good!I cant really add any super secret ideal to this post on how to do curved gl***,as of right now.To be honest with you I havent really tried to do that much of it,but I do plan to spend some time trying it soon.But I can tell you a few things I picked up,along the way,about doing gl***.Temputure is always a factor,in gl*** cutting.Its best to cut gl***,at a good room temp.,65 to 75 degs. gets the best results for me.Store your gl*** at about that room temp. at least 5 or 6 hours before you cut it.Dont store it in a cold place or hot place,and then just start cutting on it.Gl*** is like most other materials,it cuts best once the temp. has stabilized.I know when you are sanding it,its best to flood your sanding belt with water or some type of gl*** coolant,there are many offered out there.This will keep the gl*** cooler and your sanding belt cleaner,and also keeps the particals from the gl***,from just,floating in the air,so much.As far as cutting it with a power tool of any kind,I would say the finer the grit or tooth count on the tool,would make a smoother edge on the gl*** and probably produce less fracture cracks,but I also know the finer grit or tooth tool would increase heat,so your gonna need to flood the cutting area with coolant.As far as sanding a large amount off of the gl***,I dont recommend that.Its a lotta hard work and very time consuming.I think if you can come up with a way to cut the gl*** very close to the correct dims. and then sand off just enough to smooth up the edges,thats by far the best way to go.The sand blasting method,Ive never tried,but I have heard of this being done before,and I think with the right blaster,correct abrasive,and good tape to protect the gl***, it would probably,induce less heat into the gl***,than cutting it,in other ways.
    In finishing, all I can say is there are many factors,that can come into play while cutting gl***.No matter how much gl*** you have done in you life time, shhhh happens.Gl*** quality is a big factor.I have better luck cutting new gl*** than old, practice on old stuff,cut the new last.Some gl*** you get,seems to have added stress in it,no matter what you do,it just wont co-operate.I believe this has a lot to do with where it was made and that process, again the almighty dollar,hits us in the rear!
    Some days you can do no wrong and others you need to walk away and come back with a better out look,its a lot cheaper in the long run.
    And the hardest thing for me to learn,was to stay relaxed and look at it as just another job,dont let it scare you,its gl***,it will break,the world goes on, once I learned to look at it like this, my success rate went way up.
    I plan on keeping an eye on this post, Im just like everyone else here,I want to here your ideals,this is something that has caused big problems for rodders for as long as I can remember.I am sure we can all come up with a good way to solve this problem,if we just put our heads together.
  24. <font color="red">I can attest to Old beet's gl*** skills .....AND his lack of cel phone skills.....saw his merc and saw his son try to get ahold of him on the cel phone for like 3 hours today!!
    R E D M E A T </font>
  25. atch
    atch
    i don't know squat about cutting gl***. i just have a question: has anyone tried the water jet for cutting gl***? seems like it would be instant cool and maybe not so likely to break.
  26. old beet
    old beet
    I've tried it(Hydro Sabre Tech.) I works really great on flat gl***. Leaves an almost polished edge. Heres the problem, it is critical that the jet stream is a certain distance from the gl***. It shoots a water jet at something like 25 thousand plus psi. The machine is not equiped with a contour guide or any means to back up the curved gl***. It may be posible someone makes a water jet cutter similar to a bandsaw setup, that would work well with some testing. And by the way it cut TEMPERED gl*** for a very short way, before it broke.......OLDBEET
  27. as an add on to this post and to bring it back to the top-I got myself out of a jamb today with the tile saw trick.....reggie cut my windshield halves for the 40 Ford sedan Im working on-he always cuts exact to my patterns.,and I made the patterns so it was MY error....one was tight in the upper corner.I was installing them in a cut down stock gasket[3"chop] and ALSO was V-****ing the center SEAM......it also was too tight[Damn my patterns again!]anyway he was at work by the time I got home so I was on my own here....I took the tile saw and cut about 1/8" off the right side and upper corner and a trace across the top a ways-then cut 1 saw blade off the entire centr end of that gl***.....tried to reinstall- it was tight at the top of the center Vbut splice still1Damn....so I thought well I was lucky so far what the hell-I put it back on the saw and sawed a tapered cut from thop fading to zero at the center of the height and stopped there.....It worked and now my too big gl*** is installed! I had cut on three sides and twice on two of the three!no cracks.Then I sanded the edges with a DA sander with 80 grit cause thats all I have to use.....Whew! I feel like an after *** cigarette![I dont really smoke either] [​IMG]
  28. manyolcars
    manyolcars
    We have a bandsaw that uses a diamond blade and a water pump. The cuts are EXCELLENT, fast, easy, no breakage.
  29. M'O'Kars-I wonder how the blades are as to cost?[bandsaw] is your saw just like a woodworkers bandsaw? Also I notice a cople probs with the tile saw- it throws water[and gl*** powder] wet at you then it dries and becomes dust -so wear prtective gl***es and an apron. another deal I encountered was the gl*** on the table of saw can scratch as you slide the gl*** across it.I wiped it clean every time and layed a shop towel under the gl*** to slide it on so it would eliminate that problem-Thanks -Kenny
