Technical CWC Camshaft specs - Need some help
Discussion in 'The Hokey Ass Message Board' started by wizard of Oz, Jan 29, 2024.
  1. wizard of Oz
    wizard of Oz
    Folks, I have a CWC camshaft - perfectly new and unused but I can't determine the engine it is for - I am ***uming a SBC.
    The details I have are:
    serial number on the bolt end of the shaft - 41263S
    Cast numbers located in between the lobes are: CWC K34 USA1 D10 21
    Can anyone point me in the right direction?
    Thanks. 20240129_104608.jpg 20240129_104532.jpg 20240129_104522.jpg 20240129_104512.jpg 20240129_104456.jpg 20240129_104448.jpg 20240129_104441.jpg
  2. 427 sleeper
    427 sleeper
    Are there any number's on the back end of the cam, or any marking's at all for that matter? That number on the front look's to be 412639.
  3. CWC is where the casting originated. They provided most of cam cores for as long as I can remember.
  4. Rex_A_Lott
    Rex_A_Lott
    Yep. Anybody could have ground it. @Pete1 Has been around cams a long time and may be able to help. You could jig it all up with a degree wheel and a dial indicator and check it yourself. There is a machine called a Cam Doctor that will check it, some professional engine builders have one, as do most racing ***ociations that require crate motors or spec engines. Not sure what that would cost you. Might be cheaper and faster to just buy a good known cam/lifters from a reputable manufacturer. Good Luck.
    wizard of Oz likes this.
  5. wizard of Oz
    wizard of Oz
    The number stamped is 41263S
  6. I’m with the sleeper man,,,,,,,it looks like a 9 in the stamp,,,not an S .
    Tommy
