Technical Cylinder block cleaning...
Discussion in 'The Hokey Ass Message Board' started by hipermax, Mar 30, 2014.
  1. hipermax
    hipermax
    from NC
    Quick question, I have a small block I want to clean up a bit, just knock some of the surface rust off the cylinders so it looks better to sell,'or maybe I'll use it. Not sure. My question is can I just use some oil on a a scotch bright pad? Sounds like a dumb question but I just want to check.
  2. GRX
    GRX
    from MD
    Yes. Never mind the detrimental effect to the cross hatch because the cylinders are rusty and need to be re-bored anyway.
  3. hipermax
    hipermax
    from NC
    Thanks, what about running a finishing hone though? I didn't think of that until after I asked the question.
  4. GRX
    GRX
    from MD
    A ball hone you mean? Yeah, that will work but you have to do the cross hatch pattern right. That is your ring's oiling system.
