cylinder sleeves
Discussion in 'The Hokey Ass Message Board' started by merc49, Jun 11, 2013.
  1. merc49
    merc49
    from illinois
    Has anyone had merc flarhead sleeved.i have a cracked cyl. And the machinist said he could sleeve the block for a $100 a hole.the engine was rebuilt 2000 miles ago and was running great, the rear cylider was cracked half in. From the top.do the sleeves make it like new and will they last.
  2. HOTRODPRIMER
    HOTRODPRIMER
    I never sleeved a Flathead but the 327 in my Deuce pickup has a sleeve and it has over 15,000 miles so far,,no problems. HRP
  3. 36tbird
    36tbird
    Suggest you go over to the Fordbarn.com with this query. Machinists like Ol'Ron will answer your question. When you go there, be armed with pictures to post with.
    I have the tools used to sleeve a block, but have never done it. I'll be interested to see the answers you get.
  4. HOTRODPRIMER
    HOTRODPRIMER
    I suspect it's much easier to sleeve than find a good Flathead block. HRP
  5. PackardV8
    PackardV8
    Yes, blocks are sleeved every day and done properly, are serviceable.
    Before you invest in a sleeve, have the rest of the block magnaflux checked for cracks and pressure tested. I've never seen a flathead block which wasn't cracked around at least one of the exhaust valve seats.
    While it's in the machine shop, install hard exhaust seats if you haven't already done it.
    jack vines
  6. falcongeorge
    falcongeorge
    from BC
    I've never sleeved a flathead, but I have made over 600hp with a block with two sleeves in it, later it was sold to a guy who raced for a long time after that at slightly reduced power levels. I have no problems running sleeves.
  7. Dale Fairfax
    Dale Fairfax
    I've got one with 6 sleeves in it and it seems to be fine.
  8. nali
    nali
    IIRC, some european cars were sleeved from factory .
    And what about the VW flat four ?
    Done properly, I don t think it may cause a problem. But I m not machinist ..
  9. afaulk
    afaulk
    I have 3 racing engines. Each has 8 sleeves. Done correctly sleeves are not a problem.
  10. Ole don
    Ole don
    Fit the pistons on the loose side, if they are too tight, they can move the sleeve.
  11. tig master
    tig master
    from up north
    Simple job at a good shop.
    T
  12. RayJarvis
    RayJarvis
    sleeved all 8 cylinders on my 368 Lincoln. runs sweet . just make sure the engine has enough meat to accept a sleeve
  13. Gene Boul
    Gene Boul
    Some flatties came from Henry with sleeves. Don't remember which ones! KB, Milodon, Pisano etc. all had sleeves.
  14. terryble
    terryble
    from canada
    I cannot imagine how tight a piston would have to be to actually move a properly installed sleeve!
  15. rottenleonard
    rottenleonard
    Even if you only sleeve one hole the rest will need to be bored as when the sleeve is pressed in it will distort the cylinders next to it and they will need to be bored concentric again(in case you didn't already know)
    I talked with the owner of H&H flatheads he told me they sleave all cylinders now regardless of condition(he was talking the 4 bangers, not sure on the v8s)
  16. groundpounder
    groundpounder
    If the sleeve moves.....probably wasn't installed right!.....ran a lot of engines with sleeves......built (back in the day) a lot of FE and Hemi engines with sleeves....
  17. Way to tight to run anyway .
  18. ronnieroadster
    ronnieroadster
    Repairing a cracked cylinder on a flathead Ford V-8 is easy to do we do it all the time. But you should check for cracks by the valve seats that's usually where the crack starts. If you find a crack by the valve seat that's easy to repair also.
    Ronnieroadster
  19. 56don
    56don
    How do you go about doing that?
  20. tig master
    tig master
    from up north
    Metal s***ching old but does a good job.
    T
  21. Dreddybear
    Dreddybear
    Back when I was racing Porsche 944s it was standard to sleeve the aluminum blocks when building for power. The blocks were etched from the factory to expose the silicon particles which made it possible to run crazy tight clearances. Once you bored the block that was ruined and you'd have to sleeve it so it became standard practice. These days you can actually have them nikasil treated to restore these qualities.
