Cystom Motor Mounts, Where to get tube bushings?
Discussion in 'The Hokey Ass Message Board' started by Dakota, Dec 8, 2011.
  1. Dakota
    Dakota
    from Beulah, ND
    I am designing a set of Motor mounts for my Model T Update, and i am wondering where you all are getting your bushings, the ones that are like 2" long that go into a 1.25 Tube?
    I see speedway has them in like a custom kit with everything for a SBC, but all i need are the short pieces of tube with the bushings in them.
  2. carsluTT
    carsluTT
  3. Dakota
    Dakota
    from Beulah, ND
    thats a kick**** website! thanks!
  4. carsluTT
    carsluTT
    thanks, i use lots of their supplies on customers projects. ruff stuff is a small shop and they have never let me down when i order parts.
  5. 117harv
    117harv
    X2...thanks for the link.
  6. yardgoat
    yardgoat
    X3 for the link,good luck on your project............YG
  7. Yeah, great link! I've been looking for those interlocking tube attachment pieces and that's a great price on them!
  8. 37RAT
    37RAT
    from Wisconsin
    You might want to know that those bushings are a type of plastic, not the good neoprene rubber--enough said
  9. Atwater Mike
    Atwater Mike
    Who lubes plastic bushings? (proper way is to use Ultima, or a 'lubricating' material)
  10. Mark68
    Mark68
    not sure if there the right diamensions for you but i used a set of bushings from a brand new shock absorber that i only had one of,also cut the tubes off the ends also
  11. Dakota
    Dakota
    from Beulah, ND
    ok Fine, if they are plastic, where do i get the good ones?
  12. scottybaccus
    scottybaccus
    I use Chevy truck leaf spring bushings. Most parts stores have the poly replacements, but the OE rubber works fine, too.
  13. FrozenMerc
    FrozenMerc
    Try Energy Suspension. High quality Urethane bushings for tons of applications and universal bushing sets as well. Summit and Jeg's are both dealers. I built all of my 4-link links using their bushings.
    http://energysuspension.com/
