Dan from central FL
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by thhols, Jul 27, 2021.
  1. thhols
    thhols
    Hi all, I have registered quite some time ago but only now I`m back working on some of my cars (50 Ford coupe, 32 3 window, model As +). The 32 is just in storage and is a long term project. Plans are for a flathead 8ba with s10 T5 or inherit a 283 form the 50 coupe.
    The 50 is a running driving car, has a SBC/ th350 but they were swapped in the mid eighties and need work. Leak oil everywhere, engine mounts are loose and where just poorly done. Plans are to put a SBF and a T85 3speed with R11 overdrive to keep the column shift(already on the works). Pic of the 50 is my profile image. Eventually will need some info on the T85 swap, linkage etc and as the time arises will post again.
    Thank you all in advance Daniel
  2. pprather
    pprather
    Welcome to the discussion. I see you've been a member for ten years, but this is your first post.
    Looking forward to the build of your shoebox.
    Welcome from Illinois.
    lothiandon1940 likes this.
  3. thhols
    thhols
    Hi Phil, yes that`s right, quite a while!!
    I will post more stuff from the shoebox as it moves along.
    Dan
  4. floridafarmer
    floridafarmer
    from Florida
    Dan,
    I'm in Central Florida and have a friend that is moving his workshop and cleaning up in the process - he's about to toss 7 or 8 flathead Ford motors in the dumpster... If you have any interest - let me know quick before he s****s them. There is also a Ford 302 fully ***embled that was running great when put in the container I'll try to post a pic I took yesterday when I was over there.
  5. thhols
    thhols
    Hi Yes probably do. If you have any more info let me know and/or how to contact him.
    Thank you
  6. caraddict
    caraddict
    I’m in Florida and need an 8BA. How do I get in touch?
    Many Thanks
    JC
  7. fabricator john
    fabricator john
    from venice fl.
    howdy and welcome, im a neighbor kinda ,, im in venice fl. im a flathead fan finishing up my fathers 27 ,,, im in on dumpster diving lol ,, dads place is over in lake wales and get out that way often ..
    see ya at shows , ,,, goin to the moonshine reliability run ?
    fabricator john
    miss you dad
  8. thhols
    thhols
    Hi John, cool keep up the work on the 27!!
    Yes planning on going to the reliability run, may just on Saturday on the Garlits museum. May be see if the shoebox will make it!!
