Dang messy Duraglass .. Help
Discussion in 'The Hokey Ass Message Board' started by 54caddycoupe, Oct 11, 2011.
  1. 54caddycoupe
    54caddycoupe
    I just glassed the patch panels with some duraglass. It didnt go on smooth and left a bunch of holes. can i just let it cure and reapply some regular bondo over the duraglass to smooth it out? Any words of wisdom out there?:confused:
  2. Providing you mixed it with the proper amount of hardener, you can apply regular bondo over with no problem. If the holes are pin holes, you could get away with spot putty. I normally don't use duraglass for seams like around patchpanels, I normally use it where strength is more important.
  3. badshifter
    badshifter
    Pics. Did you install patch panels with Duraglass? Splain what you did. Pics. And, pics.
