Projects Dash inserts
Discussion in 'Traditional Hot Rods' started by outkastaluminum, Aug 5, 2015.
  1. outkastaluminum
    outkastaluminum
    from Kentucky
    Hey everyone I'm considering starting a line of cast dash inserts for gauges. I've seen several online a lot of them have four holes for gauges. I'm thinking 5 would be better. Maybe a 3.5" for the speedo then 4-2" for oil/temp/fuel/amp. Any suggestions would be appreciated. I'm anxious to start making something other than gas cap!
  2. HOTRODPRIMER
    HOTRODPRIMER
    Seems like another member here is in the process of making a new inset,never hurts to have some new choices. HRP
  3. TagMan
    TagMan
    Most speedometers/tachometers would need a 3-3/8" hole, not 3-1/2" . An 1/8" oversize would make for a sloppy fit.
    I was able to fit four 2-5/8" gages, along with a 3-3/8" speedometer in my '36 Ford (the dash itself, not an insert), so making an insert for 2" or 2-1/16" gages shouldn't be a problem at all. I'd be interested to see what kind of design you come up with. Something with an art deco flair would be a welcome change from the usual billet, street rod genre.
    Just my 2¢
    Runnin shine likes this.
  4. outkastaluminum
    outkastaluminum
    from Kentucky
    Ok thanks for the info. Yea I was trying to think of something different or some design in it just not sure what yet. The gears are turning tho!
  5. Did you mean something along these lines? Do you plan on them being affordable? dash insert.jpg
    FlatJan likes this.
  6. outkastaluminum
    outkastaluminum
    from Kentucky
    Somthing like this. I drew it in cad just messing around trying to get some ideas.
    I do want to change it up some tho so it's not like all the others out there.i figure somewhere around $100 depending on how much detail is involved.
  7. outkastaluminum
    outkastaluminum
    from Kentucky
    Or this just something I found online real quick I'm at work Lol ImageUploadedByH.A.M.B.1438792522.291559.jpg
  8. geoford41
    geoford41
    from Delaware
    My only comment is to make sure the area where the gage lip rests against the surface is fully machined and not "As Cast" the one I got from **X would not allow an nice flush fit on my 2 1/16" SW gages, a real bummer
  9. cadillacoffin
    cadillacoffin
  10. No finished part comes as cast. A good manufacturer takes a machined part first, creates his plug from that and then machines the piece when it comes out of the sand. Before it goes out the door it p***es final inspection and if thee is an anomaly it goes back to have that repaired or refinished. On a large run not every part gets inspected but if there is a fail than a larger cross section of the product gets inspected and adjusted as needed.
