Technical Dash Pieces for 55 Ford Customline
Discussion in 'The Hokey Ass Message Board' started by ShawninCO, Apr 18, 2014.
  1. ShawninCO
    ShawninCO
    from Colorado
    Hello everyone.
    This is my first post. I enjoy this site. Lot of knowledgeable people here.
    Hopefully this is the right spot for this question.
    I have a 55 Customline that I had to take apart the dash. I now need to replace those hard thin black plastic strips between the side pieces and the dash and between the steering column cover and the column. I'm not even sure what the proper name is for them.
    Where can I get them. I don't see them at MAC's or the other sites I normally check.
    Thank you.
  2. Got a photo of the pieces that you removed? HRP
  3. ShawninCO
    ShawninCO
    from Colorado
    Nope. But can upload one over the weekend.
  4. ShawninCO
    ShawninCO
    from Colorado
    Here are some pictures of what I'm looking for. It's the black plastic or hard rubber insulators that go between the different trim pieces around the windshield and between dash side cowls and vertical trim pieces. I'm not sure where to buy them.
  5. JeffB2
    JeffB2
    from Phoenix,AZ
  6. WillyKJr
    WillyKJr
    from Blackstone
    Once you can identify the parts by name or part number give Ron Johnson a call @ Ford Restoration and Parts - 303-506-1866. He has a huge inventory of vintage Ford parts and will have the insulator strips you need for your double nickle.
  7. ShawninCO
    ShawninCO
    from Colorado
    Thanks Willy. I'll sort out what I need and give him a call.
  8. The piece that goes along the dash is called "Windshield Post Garnish Moulding To Dash Rubber Welt" It should be about 86" long and goes from pillar to pillar. The part number is B5A-7003127-A. The piece for the column is called "Steering Column Bracket Cover Insulator" and the part number is B5A-3683-A. I would recommend getting that parts cd the JeffB2 mentioned.
  9. ShawninCO
    ShawninCO
    from Colorado
    Thanks Dos Cincos.
