Technical Dating Tires
Discussion in 'The Hokey Ass Message Board' started by moparbrothers, Feb 27, 2021.
  1. Flat Six Fix
    Flat Six Fix
    On prior research on radial tire shelf life.
    Northern climate conditions extend life somewhat.
    But not as much as you would think.
    6 to 8 years in say Arizona might reflect 8 to 10 years Alberta.
    Mine are much older now, up to 80 mph this week and 70 mph yesterday...yikes
    Time for more used tires...
  2. Flat Six Fix
    Flat Six Fix
    Lay Oops mine were manufactured late 2013. Lots of tread left ****e gotta replace these ****ers...
  3. jimmy six
    jimmy six
    My wife’s OT car is 6 years old now with 12k miles. A light weight compact. If I were to drive cross country I’d change the tires. My pickup is 3 yrs old with 24k and we are getting ready to drive for Ca.to Fl and I’m ok with that..
    chryslerfan55 and Flat Six Fix like this.
  4. burl
    burl
    from Minnesota
    Your not the only one. Have them on a couple of vehicles and its taken very little weight to balance out and run out great. I'm not sure what all the bashing is about. They are different i don't expect the same kind of performance as my everyday drivers and all is fine.
  5. continentaljohn
    continentaljohn
    @Moriarity I have Coker Firestones on all my cars and some of them aren’t even balanced and run true and smooth.. I haven’t had any issues with any of them for 30 years I did send one tire back a few years back as I felt it was too much wheel weights on it and they replaced it no problem. I also drive my stuff maybe not cross country but if you see me at a show I’m in a old 32 with firestones.
    chryslerfan55, Stogy and Moriarity like this.
  6. Wrench97
    Wrench97
    My 93 tbird is on it's second set of tires, installed in 2011................
    The original date code is broken down as ADCD where ABC is the day of the year 001 to 365 and D is the last digit of the year made so 1949, 59, 69, 79, 89, or 99
  7. rusty1
    rusty1
    ...probly most of us are running on out-dated tires,...if they recommend 5 years life,..I've had very good luck with Cokers (radials)
  8. Bob Lowry
    Bob Lowry
    Me, too..they kept me going around in circles and gave me the cold highway shoulder....never again.
  9. Budget36
    Budget36
    I don’t think so, but just like anything with a review, we hear the most from dissatisfied folks. Folks that are happy with what they have don’t complain and in most cases don’t come back and talk about a good thing.
    I used to get annoyed when I’d get an email to review what I bought, via AZ, Summit, etc. then I got to thinking, why not let others know that the “**x” fit good and works good “.
  10. So from what I have learned is , any tire with a 3 digit code is too old. Also no way to determine which decade they were made.
    chryslerfan55, Just Gary and clem like this.
  11. tim troutman
    tim troutman
  12. tim troutman
    tim troutman
    I have had around 7 sets of Coker tires both radials and bias mostly good results. 1 bias way out of balance only good for a spare in my opinion but not Cokers. bought a replacement. 1 radial belt's broke they replaced after returning it I think it was 4 years old.at the price they are now and a 6 year life for radials I am not running any now
  13. RmK57
    RmK57
    1964, 74, 84 April 9th? Old Holley carbs used the same three digit date code system.
  14. HOTRODPRIMER
    HOTRODPRIMER
    May Pop Tires!
    Long before date codes. HRP
    chryslerfan55 and X-cpe like this.
  15. RMR&C
    RMR&C
    from NW Montana
    Replacing these tires today. Bought them in 1997 IIRC :eek:. Still decent tread, no cracks, but it's time.
    I think I got my money's worth!
  16. oldiron 440
    oldiron 440
    My daily driver got new tires a year ago, they had 75K on them and still had half their tread left but I had put them on in 2014. If the fronts didn’t howl I probably would have run them another two years. I don’t do much hauling anymore or need to get on job sites like I did fifteen years ago so I replaced all four with a highway tread.
    I probably would run those red lines that were pictured earlier especially when they would have only gotten driven 2K a year on my Fairlane and the rears are going to disappear very quick. Painted body color steel wheels and dog dish caps with red lines look good.
    I guess my point is you need to consider what you’re going to do with the tires tire age should be considered. Long tips, hulling, your wife and kids driver, a weekend street strip car that might see 120-130 mph along with tire condition, it all makes a difference.
  17. squirrel
    Be sure to check the date code on this thread, before replying. It's getting a bit stale...dry rot...ready to separate....
    ckh, Stogy, Bill's Auto Works and 4 others like this.
  18. twenty8
    twenty8
    Maybe we can call it a rethread...?:rolleyes:
  19. BJR
    BJR
    I ***ume when dating a tire you need to use a rubber. :p
  20. gene-koning
    gene-koning
    Should maybe use one, but the tire has its own rubber.
    Stogy likes this.
