Projects Dave50`s craigslist 32 5w
Discussion in 'Traditional Hot Rods' started by Dave50, Jul 7, 2011.
  1. RAT "T"
    RAT "T"
    oh, it was the first time i've seen it parked on the side toward cap
  2. Dave50
    Dave50
    I keep it there when i have to use the lift etc
  3. RAT "T"
    RAT "T"
    Are you giong to run that at the drags at fitchburg airport?
  4. 32 hudson
    32 hudson
    Toeboard and floor are looking good Dave.
  5. Dave50
    Dave50
    Thats the plan but I broke a trailing arm mount lastnight
    Thanks it is better than the cardboard and got the sheet metal for 22 bucks
  6. Dave50
    Dave50
  7. F&J
    F&J
    Trailing arm....? .. meaning the 49 Olds arms for the rear end?
    If, yes... which end of it?
  8. BAD PENNY
    BAD PENNY
    from mass
    Dave, the toe board and hump look great !! Met Scott at Kimball's and worked on the coupe some more today. Let's hook up for the Fitchburg Drags if you are parking it. If you are gonna run it you'll be in the pit area. Stay in touch. Brett
  9. Dave50
    Dave50
    Frank The front of the trailing arm where they plucked a tie-rod up through frame , I put a tapered slug and tached it and it cracked the frame and tore out.... I was hoping to change it over winter but it wont last IDK what to now. I was going to keep the olds trailing arms but running parallel like they are and welded rigid just wont work. Going to take some time to figure out.
    Brett how was the latemodel and corvette show :rolleyes: all yuppi`s. Hope it was a good time did you take your car? I will be in the pits and i beleive you can roam around there too if not i`ll look ya up. You may beable to see me at the autograph session aswell :p
  10. 32 hudson
    32 hudson
    Sugestion for the tappered slug/tie rod situation. Take a piece of flat bar or angle ( 6 or 8 inches long ) at least 5/16thick , same witdth as the inside bottom of the 32 frame. Drill a hole to accept the od of the slug, weld in the to flat/angle bar and a matching hole in the frame for it to go through. Mount the flat/angle bar inside the frame by welding or temporary with 4 bolts to get through end of this season. Might have to grind on the outside edge of the flat or angle corner because there is a slight radius inside corner of the frame rail for a good tight fit in the corner.
  11. BAD PENNY
    BAD PENNY
    from mass
    Brett how was the latemodel and corvette show :rolleyes: all yuppi`s. Hope it was a good time did you take your car? I will be in the pits and i beleive you can roam around there too if not i`ll look ya up. You may beable to see me at the autograph session aswell :p[/QUOTE
    I took the 57'. I pulled in with Scott behind me in his coupe and the parking guy tells me to park right in front with all the other new vettes....yeah right !!
    Their was some nice stuff there but as usual a lot of new **** and muscle cars.
    Not many Hamb friendly rides but the food was great.
    p.s. Maybe you can sign my Jegs hat or how about my glove box door like all those cobra guys with C. Shelby:D:D
  12. Pinstriper40
    Pinstriper40
    Dave- Hopefully you'll have better luck with your lead foot in the future! I sent out your intake- hope you enjoy it! Good to see you're having fun with your '32!
  13. Dave50
    Dave50
    Brett if its a black hat i wil use a black sharpie,yellow hat yellow sharpie. On glove box naaa we`ll let Dave S have that.
    Joel thanks for update. Seems like everytime i enjoy it something breaks.... ughhh
  14. F&J
    F&J
    It's not broken.
    There is a poser phrase for everything these days.
    "Structural Patina"
  15. Dave50
    Dave50
    It has plenty of (structual Patina) Frank lol
  16. Dave50
    Dave50
    Outta the blue yesterday Jake started sputtering and fluttering just off idle then would pull hard and was fine. I have checked everything twice cant find what it is been racking my brain for 2 days. I will be at the orange drag reunion but i dont think i will race its not worth it if its going to act up. Stop by and say hello.
  17. RAT "T"
    RAT "T"
    DAVE, IT'S NOTHING! SPEED BUGGY USE TO DO THAT ALL THE TIME. :)
    http://www.youtube.com/watch?v=3hx-hEWl10c
  18. Dave50
    Dave50
    HAHAHA Well If jake sputters off the line like it has been its not going to get of the gate well at all and in 330 Jake just starts to get going :( But i am sure we`ll have a good time.
  19. 327-365hp
    327-365hp
    from Mass
    Probably just ****ty gas. See you there!
  20. F&J
    F&J
    We are coming up to see it run today. No excuses.. :)
  21. Dave50
    Dave50
    Was great to see you guys had a good time. JAKE sputtered off line all day cant put my finger on it yet but when i do i will be @ New England and show that it is better than that off the line. I lost about 3-4 car lengths off the line with it acting up. But that`s the way it goes was good seeing everyone met alot of new people where can you go for 10 bucks and have so much fun!!
  22. 327-365hp
    327-365hp
    from Mass
    It was a great time today. You were having tons of fun beating all those fancy cars. See you at Ty-Rods in the morning.
  23. RAT "T"
    RAT "T"
    Dave,
    i was sitting at the finish line watching you beat all the other cars, the car looked & sounded the balls coming down the track!
    Not sure if i'll be @ ty-rods, but i did hear the epping will be nhra certified again, i'd like to check that out
  24. brian55lvr
    brian55lvr
    from ma
    your car goes pretty good dave----i was surprised;) ---sounds great too!
  25. Dave50
    Dave50
    Thank RatT I did ok need to do some fine tuning, not bad for a jalopy Idk if i can run New england but am going to try.
    Thanks Bri.... I try to build motors as well as you do paint and body work:)
  26. 327-365hp
    327-365hp
    from Mass
    Just found this pic on the Drag Reunion thread. Looks like concrete evidence to me. :D Thanks to Markl350 for the pic.
  27. Dave50
    Dave50
    LMAO off thats a good pic thank god he didnt snap it later Pete was driving by me top end spinning the RR:D
  28. coupemerc
    coupemerc
    Dave...great to finally meet up with you at Ty-Rods. Your hot rod is just plain *****in. See ya.
  29. Dave50
    Dave50
    Was great to meet you finally LOL I really like your car as you know You done good!! I hope to see ya @ ALTERBOYS saday:cool: Thanks i am glad you like Jake I like him to:) Hope to caravan down with a few people
  30. Dave50
    Dave50
    A few pics from the awesome weekend, A few of my car Pete Flavens awesome 3w and the yellow nova is what beat me in the final elimination :eek: Thanks to mark for the pics great pics!
