Projects Dave50`s Model A Build
Discussion in 'The Hokey Ass Message Board' started by Dave50, Mar 2, 2011.
  1. Dave50
    Dave50
    LOL slick willy I am so FORTUNATE cant wait to see you guys at the shows.
  2. Wow, you scored big time there.
    That things only a coat of yellow and four carbys away from Milners coupe!
    Very similar stance.
  3. Dave50
    Dave50
    Sure is steve but i am not gona go with that color I may just keep it as is for awhile and enjoy..
  4. Dave50
    Dave50
    Well its been a hot 4th got to work on the 32 finally it just got here wensday. I put a battery in to see if she would crank,it does by hand.I looked at the wiring and said this is gonna be trouble so now i will rewire the whole car it will be in my best interest in the long run and it shouldnt take much, a horn,lights,starter,distributor and Generator. I got all the wheels off,wheel cylinders,master cylinder ,water pump,Generator,Radiator and grille shell. Also the brake lines, I need to replace the brake system. I did tear apart the wheel cylinder`s to see if they will take rebuild kits but after 45 years of sitting they are rusty and pitted pretty good even after honing and cleaning them. I still have to remove the intake and carb to put my 4x2 with 9`s on :) or rebuild the 4bbl:rolleyes: The radiator looks really good except the bottom outlet, it needs a little attention. I also found out that the 4x2 intake doesn`t have Generator mounting brackets cast into it. Looks like some old school fabrication. So now to figure out where to get all the parts to fix. Does anyone have brake shoes in stock for juice brakes i ned a set of fronts. LET me know what you think
