DC motor drives
Discussion in 'The Hokey Ass Message Board' started by fireguy976, Mar 20, 2009.
  1. fireguy976
    fireguy976
    from to
    Hi,
    I just bought a 1/8 hp right angle DC motor to power my bead roller.
    Still on a learning curve here (in other words I dont ****** know:rolleyes:) regarding hooking up a Dc motor.
    When you see others hooking up their motor kits, I dont see any transformers, or curcuit boards, etc.
    I do know its not a straight plug in.
    Any help would be appreciated.
    Thanks all,
    Ken J
  2. What voltage is your motor?
  3. HemiRambler
    HemiRambler
    On one I used a off the shelf SCR controller - RELATIVELY CHEAP. On another we made a little ciruit - depending on motor voltage you likely need a tranformer. IIRC the one I am thinking of utilized 90VDC motor which works out real well after it's rectified. I'm sure you can look up some basic schematic on the web.
  4. 4-pot
    4-pot
    You need a controller but I don't think 1/8 hp will do the job. I have a 3/4 hp d.c. motor on my bead roller with a Reliance variable speed drive.
