De-rusting
Discussion in 'The Hokey Ass Message Board' started by easyrider47, Nov 12, 2007.
  1. codyn
    codyn
    try hooking the charger up to a battery and the solution at the same time. My charger dosent "see" anything there if there is no battery there.
    It worked great after I hooked up a bad battery in line with the solution.
    But an arc welder set on DC at its lowest setting seems to work way better than a battery charger.
    Just be carefull because all those slimey bubles in the solution are hydrogen (although it is fun to pop them with a torch!)
  2. cmh5557
    cmh5557
    Yes! It's working. Just had to add a battery to the circuit. Lots of bubbles. The battery charger has a safety feature. No battery, no current. Thanks to everyone who responded.
    Craig
  3. Mark in Japan
    Mark in Japan
    be sure to post a pic straight outta the bucket, before you prime it
