De-smogging an '85 302....?
Discussion in 'The Hokey Ass Message Board' started by Flynn's_57, Dec 4, 2007.
  1. Flynn's_57
    Flynn's_57
    from Nor*Cal
    So I'm curious about the difficulty/cost involved in removing the smog "accessories" from an '85 (carbed) 5.0 mustang motor...?
    It's going in a "pre-smog" machine and I'd like to get as much HP out of it as I can, plus smog stuff gets so #!$%&* confusing (to me?)
  2. Oldschoolhotrods
    Oldschoolhotrods
    from san diego
    remove and plug the holes for the most part, simple task
  3. SlmLrd
    SlmLrd
    from DAGO
    Yup, remove all the smog ****, plug up some holes and GO! Theres really nothing to it.
  4. Da Tinman
    Da Tinman
    Plug the smog pump vaccuum side into the valve cover, instead of your pvc valve,, pick up a few hp!
  5. atomickustom
    atomickustom
    If you change the intake manifold you automatically eliminate the EGR valve and any excess vacuum ports that you won't need. That gets rid of 99% of the **** on '80s motors.
  6. SlowandLow63
    SlowandLow63
    from Central NJ
    After that just two plugs on the back of each head and your done.
  7. tjm73
    tjm73
    Pull that big, heavy, ugly smog pump off it too. Should be on the lower p***enger side.
    Someone (Steeda I think) makes a crankcase ventilation system that bolts into it's place. Could net you an extra 30ish hp.... Something to consider.
    BTW...if you want to ditch the reverse flow water pump and still run a serpentine belt you can use the crank, water pump and alt pulleys from a 302 or 351W (cop car) crown vic with just the alt bracket from a late 60's to 70's 302 or 351W. It's all bolt on.
  8. Flynn's_57
    Flynn's_57
    from Nor*Cal
    Awesome!
    Much appreciated!
  9. k-member
    k-member
    Search for a post by "Bull" it has step by step with pics.
