Dead Cylinder
Discussion in 'The Hokey Ass Message Board' started by Von Rigg Fink, Aug 10, 2010.
  1. carcrazyjohn
    carcrazyjohn
    from trevose pa
    So you were ****ing number 1
  2. Von Rigg Fink
    Von Rigg Fink
    from Garage
    You did have to put it that way , didn't you :p
  3. carcrazyjohn
    carcrazyjohn
    from trevose pa
  4. ironpile
    ironpile
    A properly operating pcv valve shouldn`t affect idle or EGT on one cyl. How are the VC gaskets?
  5. lippy
    lippy
    from Ks
    Glad you nailed it Randy! Sometimes these old engines have a mind of their own. You methodically diagnosed it and nailed it. Way to go now get that thing together and have some fun! Better to have a problem now than after the car is together! Good on ya Randy! :cool: Lippy
  6. lippy
    lippy
    from Ks
    LOL. Lippy
  7. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    Party? What Party !!!
  8. canman
    canman
    In this case with a new engine(little or no HC in the crankcase) and the traditional breather in the right valve cover it's uncompensated air(lean) and all going to that runner. I buy it,makes sence now that he knows what it is. Your correct that a pcv shouldnt cause a miss and plumbed right now it won't.
  9. bobss396
    bobss396
    And how! I figured it was something off the wall and would be free to fix, just had one of those feelings about the problem. I mean, the compression was good, all the electrics were cooperating and you did have an adequate fuel supply, what else could you need? Maybe a PCV valve that played well with others, lol.
    Bob
  10. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Well,,, aparently thats not true;)
    shes hitting on all 8 now, it was like flicking a light switch
    i believe it had alot to do with the location of the feed port
  11. djust
    djust
    from Oklahoma
    Congrats man glad you got it figured out, still struggling with how to get a pcv setup on mine.
  12. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Ha..dont feel bad, I got the same issue now:mad:
    Im going to try and pull out of the center , like from the center carb low on the base and see how that works. im sure that would be better than pulling from an area too close to one runner or one end of the intake
  13. djust
    djust
    from Oklahoma
    Just last Friday I drilled and tapped a hole near the rear of the intake on p*** side pretty close to where the vacuum advance on the dist is and then I drilled and tapped a hole in the riser on the back carb.
    Waiting on a pcv valve to show up from NAPA so I can pick it up and try to hard pipe it in, and after what you just went through I might have to end up pulling the center carb riser off and swap it with the back one.
    I don't know we will see.
    Keep me informed as to how your turns out.
  14. 39 All Ford
    39 All Ford
    from Benton AR
    Not so long ago I had the exact same issue with initial start up on a SBF with aftermarket heads.
    We had a dead cylinder I found with a temp gun just like you. I ***umed I had a valve too tight, I "reset" the valves over, and over, and over, finally pulled the intake and sure enough the gasket had slipped just enough on the oversize ports to cause a vac leak into the crankcase.
  15. Von Rigg Fink
    Von Rigg Fink
    from Garage
    watch that one on the rear , might play with your #8 cyl:(..maybe
    my problem might also have been the size..3/8" hose typ pcv line size..but it was just a but too much for where it was..possibly a smaller set up for dist. vac. might not be a big issue?
    it also could have been from the design of the intake and the placement and size of the vac. line too. like a combination of equipment that added up to one big PITA..
    i think im going to use ported vac for the distributor..little better that way no dive on the vac when you stomp on it..
  16. djust
    djust
    from Oklahoma
    The way my carb setup is I have to use the manifold vac for distributor.
    According to ****ster the carb vacuum ports were blocked because the old holleys needed a special vac signal from a certain distributor and mine would work better hooked to intake vacuum.
    I tapped the holes in the intake and riser with 1/4" npt but I guess I could use any size piping, but the pcv valve that is coming also had 1/4" threads on both ends so details, details, details, they are killing me one after the other.
    Soon as I get the pcv figured out I can fire it up and see what happens.
    I just hope the tri-power set I got from ****ster works okay because I sure don't know anything about these 94's I have.
  17. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Im sure that will be fine..your vac. advance will work more like a load compensator than how ported vac works, but if you can get enough innitial timming in it, you'll be fine.
    im going to try and un cork one of my ported vac. from off the center carb, and see if that works ok, if not,,, back to block below the ****erflies
