Dead wiper motor?
Discussion in 'Off Topic Hot Rods & Customs' started by Ian Corner, Jun 29, 2024.
  1. Ian Corner
    Ian Corner
    Wiper motor decided to quit on my 63 Fairlane, troubleshooting info has been hard to find online, I’m hoping someone has done some troubleshooting , power to the motor, grounded properly, took the motor out, I can energize the field , but motor will not move at all. Clicking within if I jump the other two connections. Brushes are good, armature is clean. There is so little info about this motor anywhere… any motor upgrade anyone has done? Many thanks
  2. squirrel
    Do you have the factory shop manual for the car? I have a 62 corvette, and have the factory manuals, and it gives complete troubleshooting and overhaul information about the wiper motor. But then, it's not a Ford.
    Desoto291Hemi and firstinsteele like this.
  3. Ian Corner
    Ian Corner
    No, have not been able to find any factory service manual, pretty much nonexistent
  4. squirrel
    huh, there are several 1962 used original manuals, and 1963 supplements, on ebay right now. Not expensive.
    Zuffen, Bob Lowry and Desoto291Hemi like this.
  5. RodStRace
    RodStRace
    What Jim said.
    Wipers are the one thing that really messes with people's heads where electrical is concerned.
    They have constant power. When you hit the switch, it supplies ground to a set of contacts inside to start the motor.
    When the motor is triggered, it moves out of the park position and closes a contact that supplies that ground through another set of contacts UNTIL it's at the park position, then those contacts open, shutting off the internal ground circuit. If the switch is still on, it supplies the ground and it keeps moving. If you shut off the switch, the switch ground is not provided, but the internal contact stays closed, supplying ground until it reaches park, then opens. They typically don't show the mechanical switch inside that opens the ground circuit for park.
    The ones that back up to park are even more complex.
    I did see a number of comments on the 63-65 wipers, and how the motors are rebuilt and upgraded.
    There was also mention that trying to turn the wiper can cause internal damage, probably to that internal switch.
    klleetrucking and OzMerc39 like this.
  6. squirrel
    Maybe @67drake has the 62 Fairlane shop manual and could scan a few pages?
  7. RodStRace
    RodStRace
    OzMerc39 likes this.
  8. southerncad
    southerncad
    If nothing else, have you looked into Newport Engineering, they make wiper motors for a lot of older rigs...just a thought.
  9. JohnLewis
    JohnLewis
    I think the wiper motor set up is the same from 63-65? This is the 65 manual
    [​IMG][​IMG][​IMG][​IMG]
  10. Ian Corner
    Ian Corner
    That is amazing thank you! I’ve tested this motor every way possible and I can only energize the field , motor is magnetized but does not turn, only clicks internally. Again thanks for the pages!
    RodStRace and JohnLewis like this.
  11. JohnLewis
    JohnLewis
    Glad to help, amazing community here. Like to contribute. I enjoy more of the hunt in finding something that can benefit someone and share.
    klleetrucking and RodStRace like this.
  12. Ian Corner
    Ian Corner
    Many thanks, with all the help here, sadly all the testing points to a dead short in the motor.
    Just have to figure out how to get the armature out…..cheers
  13. klleetrucking
    klleetrucking
    from Dalzell,SC
    If you can't get it fixed yourself this outfit might be able to help, https://www.cl***icwipers.com/
    He does not sell parts but will rebuild yours, nice guy too. BOL
