Death Wobble Poll
Discussion in 'The Hokey Ass Message Board' started by flathead31coupe, Mar 12, 2010.
  1. Tires.
    38 vote(s)
    12.7%
  2. Loose or warn parts
    81 vote(s)
    27.0%
  3. Caster angle
    50 vote(s)
    16.7%
  4. Front end geometry
    104 vote(s)
    34.7%
  5. other issue,pls state what you think...
    27 vote(s)
    9.0%
  1. flathead31coupe
    flathead31coupe
    from indpls, in
    thats some funny $hit right there :)
  2. Torana68
    Torana68
    from Australia
    might be the way you took the photo but whats the camber setting, looks very +
  3. Hotrodbuilderny
    Hotrodbuilderny
    I have had plenty of axled street cars, only one the opel wagon use to give me the shakes if you hit the right series of ruts, 7degrees caster just like the rest of my cars everything new ended up putting a steering damper on it, solved the problem but I never knew why it did it and none of my other cars did. mine was a side to side shake not an up and down mine was a dual spring car if you have a transverse spring
    maybe a panhard bar would help. and I agree if that axle is level that camber looks bad
  4. damnfingers
    damnfingers
    Won't adding a steering damper just mask the real problem?
  5. flathead31coupe
    flathead31coupe
    from indpls, in
    when it shakes, its side to side, looks like the wheels are jello, shakes your teeth loose untill you slow to a stop, then go...
  6. flathead31coupe
    flathead31coupe
    from indpls, in
    it looks like the sprint cars when they wobble on start up lap at times...
  7. flathead31coupe
    flathead31coupe
    from indpls, in
  8. Russco
    Russco
    from Central IL
    Are you sure you have 7* caster?
  9. madpole
    madpole
    i had the same problem, and a steering damper fixed it....i used one of the ones socal sells. i don't no what caused the problem, but i have been driveing the car for a few years now with the damper and no more death wobble
  10. Hotrodbuilderny
    Hotrodbuilderny
    an awful lot of vehicles come from the factory with them. I do agree about the band aid effect, but I could never find the reason that one car would have the shimmys and none of the others did, Chevy even put them on monte carlos to cure the shakes
  11. squigy
    squigy
    from SO.FLO.
    Yep $20.00
  12. flathead31coupe
    flathead31coupe
    from indpls, in
    +1 on this
  13. T. Scott
    T. Scott
    to many beers .... LOL seriously i think Ol Deuce may be right you may want to check the axle
  14. Hotrodbuilderny
    Hotrodbuilderny
    I personally would not want a steering damper on my fenderless coupe, I was just telling of my experience you might try taking some caster out go to 3 or 4 degrees
    worth a try
  15. flathead31coupe
    flathead31coupe
    from indpls, in
    when i had the cowl steering it did the same thing, went with a better box, on this setup still does it.
  16. gimpyshotrods
    gimpyshotrods
    Any one, several, or all of those can cause it, in my experience. Check them all.
  17. flathead31coupe
    flathead31coupe
    from indpls, in
    started out with around 4 or 5, then made it 7, it seem to me it wasnt as bad at the 4 or 5 as to its is now at 7...
  18. Hotrodbuilderny
    Hotrodbuilderny
    Give it a shot at 3 other than time what have you lost
  19. Rex Schimmer
    Rex Schimmer
    from Fulton, CA
    I had (have) the same problem on my roadster and it is best(least shimmy) when the toe in is as close to zero as I can get it. Another thing is the cross steering rod, what is the diameter? You may need to put a sleeve over it to make it stiffer.
    Rex
  20. 51ChevPU
    51ChevPU
    from Arizona
    You might need a front panhard bar if your doing the wobble. It will keep the axle centered for you and wont dance around.
  21. chopt top kid
    chopt top kid
    Just for grins, how about changing out the front wheels and tires with your buddy and see if it still does it. A few years back I bought a brand new set of aftermarket wheels and put on my straight axle front end... Death wobble out the a$$. I figured that the front was worn so I changed out everything, kingpins, tie rod ends, checked caster, camber, toe in, nothing helped. I took those wheels off, and the wobble went away. It had to be the wheels???
  22. davidwilson
    davidwilson
    from Tennessee
    12 degrees caster, balance tires on 2 machines (to check machines), 1/8" toeout, check rims for runout, suspension parts good - will not wobble
  23. Patalta
    Patalta
    Panhard Bar!! They say!! "Search" is your Friend
  24. mart3406
    mart3406
    from Canada
    None of the above! The problem is definitely, bad muffler bearings. I'm sure of this too, because I had the exact same thing happen to me on my 'Ed Roth & Tommy Ivo- built', '31 Henway "Deluxe Polecat" touring car! When Roth and Ivo originally built the car back in 1963, they only intended it as a show car - primarly for display on the Taiwanese and South-East Asian show-car circuit . Not anticipating that the car would ever actually be street-driven, they went a bit overboard on the powerplant and swapped in a completely chrome-plated, but also, fully race-modified and absolutely 'built to the ***s', 440-inch, '59 Reo Gold Comet truck engine! Shortly after I acquired the car via some overseas connections in Taiwan last year, I got the car back here and put it on the street. Naturally too, I couldn't resist and started beating on it a bit. When I did though, the original Henway muffler bearings - which Roth and Ivo had foolishly kept and used in their original build - and which were never designed to stand up to the immense torque of a radical, race-built, 440-inch 'Reo V8 - soon gave out under the strain. The muffler bearings eventually completely shattered, causing a severe vibration and front-end 'death-wobble' that was so bad, it nearly rattled the automatic-****** shift ****ons right out of the car's genne' '58 Edsel 'Tele-Touch' steering column! :eek: Believe me too, fixing it was was an absolute *****! Have you ever tried buying new muffler bearings for a '31 Henway touring car??? The problem is, that the originals were made of drop-forged, heat-treated Kryptonite and because Kryptonite is now banned by the E.P.A as a biological hazard, nobody stocks the damn things anymore! Even the guy at NAPA just looked at me like I was crazy or something and threatened to call the cops when I asked if they had some in stock!!!! :eek::eek: Fortunately, through my connections with Henway Motors in my volunteer capacity as their official corporate historian and archivist, I was given access and allowed free reign to search the attic and ba*****t store rooms of the famed 'Henway Motor Car Museum' in East Dimwit Nebraska. It took a full week of searching through old, cob-web covered parts bins and opening hundred of dusty old wooden shipping crates, but I lucked out. I was able to find one N.O.S set of heavy-duty 'service replacement' muffler bearings, packed in cosmoline and still in their original circa-1931 packaging! Once I got them home, to make sure they could stand up to the power of the m***ive race-built Reo V8 this time - and to insure against *any* possible future failure, I first sent the bearings out to have them case-hardened and then. shot-peened and micro-polished. Then, 'just to be sure', (I didn't want to have to go through this ever again!) I had some nuclear physicist drinking buddies built a cyclotron in my ba*****t, where I immersed the bearings in a Boise-Einstein condensate-enriched atmosphere and then, bombarded them with electrons at 500KV and 4000HZ for30 straight days and nights! Problem solved! The bearings are now damn near indestructible! And man, do they ever work too! Since installing my new and now, "cyclotron-fortified" muffler bearings, the car rides smoothly again and goes straight as an arrow - right up to 140 mph and beyond, with nary even a hint of vibration or front-end shake! :D :D :D
    Mart3406 (Official Henway Motors Corporate
    Historian and Archivist .....and now, '59 Reo
    'Gold Comet' 440 V8 hop-up expert too!
    ) :D
  25. KUZTOM
    KUZTOM
    How large is your wife or girlfriend , trade for more user freindly model.......
  26. youngrodder1929
    youngrodder1929
    drag link not parallel to wishbone and ground ?
  27. roadsterpilot
    roadsterpilot
    There are a couple possibilities that know one has mentioned:
    If your caster is set at 7 degrees at the kingpin, what degree is the crossmember welded in at? How much rake do you have rear to front? What angle is your drag link running from the front wheel to the steering box?
    It could be possible that the 4 or 5 degrees of caster works better due to less bind in the shocks and spring which can be fixed with adjustable perch bolts and a steering dampner.
    You definately dont need a panhard bar on a side steer application, a panhard bar is used to center the axle and to stop frame roll in a cross steer frontend. The steering dampner is used to dampen steering and will not elimanate a "death wobble". I use the steering dampner to prevent road shock only.
    If your running taller tires at the rear,(which most of us do on these types of cars)., that changes the caster of the axle and the front crossmemeber.
    Im not sure if any of this helps in your situation but thats what I would take a look at, I had a similar problem a couple years ago and reduced the caster and used adjustable perch bolts to take some bind out of the spring and added a steering dampner. I havent had a problem since.
  28. andysdeuce
    andysdeuce
    Hmmmmm. Three pages already....not bad.I think you guys lost your magic smoke during front end installation and now need to replace it. Just my opinion...:p:D:D
  29. Cosmo49
    Cosmo49
    I vote for checking your wheel bearings, is the race set true and square? Proper torque?
  30. fitzee
    fitzee
    He says that if the road is smooth it is ok it only acts up on ruff roads.Leads me to think it is in the shocks. They are fighting each other causing a rebound from side to side.
    On smooth roads,how does the car react on braking and take off?Is the problem there when you slow down or take off on smooth roads?
