Death Wobble
Discussion in 'The Hokey Ass Message Board' started by blown240, May 13, 2009.
  1. blown240
    blown240
    from So-cal
    Can the front wheel toe cause a wobble? The toe on my 51 Chevy was WAAAY out, about a half inch. I have adjusted it alot closer, but now I get a pretty bad wobble. Is it possible that these are related? Or maybe the wobble is something new that I have just noticed since setting the toe.
  2. Casey
    Casey
    it needs 1/8 " toe in
    and check for worn parts
  3. sxdxmike
    sxdxmike
    is toe in for every car the same? (street cars)
  4. manyolcars
    manyolcars
    1/8" is common
  5. Mike Miller
    Mike Miller
    Your shimmy has probably more to do with worn parts, castor, or out of round tires than toe in. Does it do it all the time or just after hitting a bump?
  6. Flatheadguy
    Flatheadguy
    Casey got it right. (reply #2 above)
  7. You need less toe-in with radial tires, 1/8" is good for bias ply, but 1/16" is good for radials as radials have less rolling resistance. Adjusting your toe-in may have brought to light problems that were already there. Used to be an old used car dealer trick to toe the front wheels out a little to keep a prospective buyer from feeling handling problems due to worn front end components.
  8. 35mastr
    35mastr
    from Norcal
    I would start looking for worn parts also. The toe adjustment just added to what ever was already worn out.
  9. blown240
    blown240
    from So-cal
    It happens mostly just after hitting a bump. And then it lasts until I slow WAY down.
    The tires were badly worn from the incorrect alignment, worn clear thru the first layer of steel belts. I got new ones but haven't installed them yet, I was looking for warn parts before I put them on.
  10. Crease
    Crease
    I second that.
  11. R Pope
    R Pope
    First check the third arm for play in the bushings. It's the Y shaped link on the back of the X-member. Grab it and heave up and down, HARD! There should be no play in it, any at all will cause a shimmy on some cars, others will stand a bit. Next, check the king pins. A hint...if you have to pull the front end apart, find a set of '53-54 uprights, they lower the front an inch or so.
  12. Flatheadguy
    Flatheadguy
    "Steel belts sticking through"? Damn, man, get that junk off the car. Fix the things that YOU know are wrong and then come back with questions.
    Want to add "duh" but will just smile instead.
  13. ThePuck
    ThePuck
    from Ottawa
    Caster angle, or lack thereof is what causes wobble. Think of those stupid shopping carts with the one wheel constantly oscillating.
  14. blown240
    blown240
    from So-cal
    The uprights are Fatman, they are only a few months old. How much play if any should there be in the kingpin?
    They are already replaced. Some nice new Goodyears are on it now.
  15. ThePuck
    ThePuck
    from Ottawa
    You should not be able to feel any movement in the kingpins.
  16. Hardcore Bullshit
    Hardcore Bullshit
    from No Georgia
    And with the new tires ????? any more wobble?
  17. make sure it hasn't WOBBLED the toe way out again,,
    make sure your tires (thank goodness you swapped them) are balanced properly, and like the boys said, check for loose suspension/steering parts,,,you don't know how many times i've told customers that i can align their car, but a bad idler arm, control arm or tie rod end will make it NOT worth their time,,,,and it'll be back out of alignment within a SHORT amount of time,,,,
    xoxox
    miss hootch
  18. Dave K
    Dave K
    I would check the shocks the only really bad wobble I have had was from shocks that are broken in half.
  19. Brad54
    Brad54
    from Atl Ga
    Dave tree'd me. Check your shocks. I had that problem on my '62 Suburban. It'd wobble at different speeds, rpm... only constant I could figure out was when I pushed in the clutch it would clear up.
    Turns out pushing in the clutch broke the "cadence" of the suspension by taking the power out of it, and the wobble would go away.
    I was working up front and pulled the shocks one day--they collapsed by hand, and didn't rebound at all. Replaced them, and the wobble was gone.
    -Brad
  20. blown240
    blown240
    from So-cal
    Its not the shocks. I was looking at it some more and I think it may be the third arm. There is a little play in it and in the kingpins. I need to see if there is anyway to adjust the third arm...
  21. blown240
    blown240
    from So-cal
    Whats the best way to get the play out of the third arm? Is it like a kingpin? If I grab it and the link to the steering box, and move/pull up on them together, I get some play, up and down. Who has a rebuild kit?
  22. fiftyfiveford
    fiftyfiveford
    Rebuild kits are available from the usual companys...
    Chevs of the 40s, the filling station or National chevy. I did mine and made a world of difference.
  23. blown240
    blown240
    from So-cal
    OK cool. I am glad there are kits available. I bet that Car SHop would have them. Unfortunatly my catalog fell in the toilet...
  24. TagMan
    TagMan
    "Unfortunatly my catalog fell in the toilet... "
    Kinda getting into that "too much information" area, aren't we?<!-- / message -->
  25. blown240
    blown240
    from So-cal
    well maybe...
  26. Flatheadguy
    Flatheadguy
    Keep us posted on the progress....the cure.
