Dec Banger meet.... Christmas on all four
Discussion in 'The Hokey Ass Message Board' started by Bluto, Dec 1, 2011.
  1. hillbilly4008
    hillbilly4008
    from Rome NY
    That is beautiful. I wish I could find something in that condition here in the rust belt.
  2. 51delivery
    51delivery
    I have a fuel leak question: We are trying to get my 1929 4 door runing for the first time since the early 1970's. We have had some sucess it ran just a little bit the other night. But a lot of gas leaks through the carb. I have adjust the needle all the way in . I know that there is a fuel shut off valve on the tank. The carb was rebuilt some time in the 1960's. We took it apart and put a rebuild kit in it even though it was very clean. Mainly for the new seal that did nto survive the dis***embly. Any input?
  3. Bluto
    Bluto
    Crazzzzz
    I like the tree growin' out the roof
    GOOD CHRISTMAS TO YOU ALL!!!!!
  4. patina steve
    patina steve
    I haven't posted on the Banger thread before I hope this picture of my Bonneville Engine is a good start. First run after engine build, hope to have it installed in the Lakstere and ready to run V4F in 2012.
  5. Hapydz
    Hapydz
    Just hope that everyone has a Bang Up Christmas and a Rock'n New Year !
    Ron
    p.s. I hope you and your's Rusty, are OK !
  6. youngster
    youngster
    from Minnesota
    Merry Christmas to all!!!
    Ron
  7. BHT8BALL
    BHT8BALL
    Merry Christmas to all & a great '2012'
    Here's pictures of the 1st operation on my new B-55 rods, they still have to have the cap finished. They are made in 7.5 & 8.0 lengths with 1.875 rod brng. & 8.0 with 2.0 rod brng. for G28 engines or a welded up or billet crank. They will be thoroughly tested in 2012 at Bonneville, Willow springs dirt track & various hill-climbs. In the pictures if you look close you will see that the aluminum rod weighs 520 g's & the steel one 730. Similar aluminum rods are in Max's roadster for 3 years now, running on the hiway, antique nationals & hill climbs. Pat
  8. BCCHOPIT
    BCCHOPIT
    I E-mailed Santa and added them to my list:D
    whats up with the pile of heads?
    MERRY CHRISTMAS TO ALL...
  9.
  10. Crazydaddyo
    Crazydaddyo
    You might have a float that doesn't float too.
  11. Crazydaddyo
    Crazydaddyo
    Ya, how about that. It ripped the rpof clean off. ;)
    Feliz Navidad tambien.
  12. BHT8BALL
    BHT8BALL
    BCC, half of the pile is for these 2 cars!
  13. BHT8BALL
    BHT8BALL
    Here's the rest of the pic's, can't send more than 4 at a time! Pat
  14. RussTee
    RussTee
    After this earthquake All OK hit most of the red zone areas very unnerving:eek: worst thing was the shops all had to close Xmas eve and I spilled my ****** beer at my Xmas breakup ****** what a ****** waste does nature have no pride. No Xmas hols for me will have to go back to work and recover what I can was looking forward to working on the truck lucky i had wooden blocks under it as it came off the axle stands no damage to it this time when will it all end.
  15. RussTee
    RussTee
    All looking good Pat up to your usual high standard now all you have to do is start making five bearing crank shafts and girdles and we will have the complete package well done.
  16. RussTee
    RussTee
    Xmas day here and man its hot down here in the south seas Merry Xmas everyone and a wonderful new year to you and yours off for a beer and the beach have a good one everyone
  17. Stovebolt
    Stovebolt
    All the best for the festive season banger boys.
    Its a hot steamy day here after summer thunder storms overnight.
    The book vouchers I got will go to buying banger books ;)
  18. NORSON
    NORSON
    Rich
    You said you based rods on chev 265 rod bearings, wrist pins, etc. Boy, it's been a lot of years and I remember some differences, but I can't remember what. I know I had my '55 265 out 4 times replacing broken pistons and it seems the rods were lighter? And I built a '57 265 because I liked the full pressure to the lifter galley. But, I don't remember what the differences were. ???
  19. 97
    97
    How heavy is the wooden one? :D:D
  20. BHT8BALL
    BHT8BALL
    It's made out of guitar wood and weighs 350 without the transfer punch in it!<label for="rb_iconid_12">[​IMG]</label>Pat
  21. RichFox
    RichFox
    Any 2 inch rod bearing will work including the 250 six bearings. Because the Plymouth had a 3 3/4 bore and a 2 inch crank pin it seemed the best to use SBC parts and just have a rod made long enough so that the piston came to .000 at TDC. Since I had to make the Dodge rod bearings some size and had spare 2 inch (265 and other SBC) bearings I went with the same size.
  22. RopeSeals???
    RopeSeals???
    Fuel leaks? That's just Model A Cologne No. 87 :D
    My guess would be the needle & seat might be stuck, or the float level is too high, or the float is heavy/sank...
    If the fuel valve is leaking you can dis***emble it and use a fine lapping compound to improve sealing, clean well, check/replace the stem seal, and use some fuel lube on re-***embly...
    Post some pics when you can
  23. Crazydaddyo
    Crazydaddyo
    I'm going to drive it like this for a while, add some bolt on power thanks to mr Winfeild, then up grade to a 5 speed and juice brakes. Leaving the outside alone.
  24. WDO40
    WDO40
  25. T__N__A
    T__N__A
    The straight vertical portions of the runners are about 5.5 inches long. I'll post some pics when it gets installed.
    This will use a updraft winfield carb.
  26. Michael_e
    Michael_e
    On that third pic, could you turn that head upside down so we could see the 'inside' where you milled out everything? Please?
    Mike
  27. BHT8BALL
    BHT8BALL
    Here's the pictures again, P
  28. Michael_e
    Michael_e
    Thanks Pat. I really think that machine work is really neat. Do you use some special 'glue' to hold the two pieces together? And i was wondering that if you can mill a flathead like that in a cnc machine, why not go all out and make up an overhead valve setup or even a overhead cam setup? Couldn't you make the OHC head similar to the flathead and add bolt on cam towers/trays? The Cosworth BDA uses a bolt on cam tray. I'm sure there are other engines that use bolt on cam trays also. You just make it seem so easy when we look at your machine work. Thanks, Mike
  29. BHT8BALL
    BHT8BALL
    In racing you pick a cl*** to run in, in this case we are trying to build a better flathead, time will tell. Long ago Racer Brown commented on 2 cam engines, "there have been far more successful pushrod engines than overhead cam!" In today's world full of computer simulations & flow benches it becomes a matter of when to say "enough". Virtually any design can be improved after the fact. As far as making it look easy, to ruff machine the 2 parts takes 1.5 mil lines of code & somebody has to ride herd on the computer. My 1st engine in my Avatar was a supercharged flathead, many time I was told " it would go faster with a Chevy ", but I was competing in a cl*** for flatheads and I enjoyed the thrill just as much as with later engines. The sound & feel of that flathead reaching 6,500 in 3rd gear of the Muncie is with me today, I didn't set a record but I did melt 4 pistons! Pat
  30. RichFox
    RichFox
    End of year update on Dodge Bros. Bolted to trans and trans bolted to mount. Needs front mounts and several other things. But it is in the roadster
