Deck height of a 292 Ford Y Block?
Discussion in 'The Hokey Ass Message Board' started by Cliffy, Jun 12, 2012.
  1. Cliffy
    Cliffy
    I am putting together a stroker Y Block to give away at this year's Symco Shakedown. I have a special Rod and Piston combo from a fellow HAMBer but I need to know the deck height on a 292 so I can double check my math and find out if there are other options for rods. I can't find it anywhere and don't have the caliper to measure my block. Anyone know what it is?
  2. Cliffy
    Cliffy
    Back to the top. Nobody knows this?
  3. mtkawboy
    mtkawboy
    Find out how thick the head gasket is and shoot for .035 total, gasket + deck. Its not a contstant, it varys from engine to engine because of stack up tolerances in production even though Ford may have a spec for it they never are exact
  4. 57Custom300
    57Custom300
    from Arizona
    You might post this question over on yblocksforever.com One of those guys should know it. Also you could contact John Mummert, his number is listed on that site also.
  5. Top Kick
    Top Kick
    Mine is at 9.755, but it has been decked and I'm not sure how much it was cut. I don't have the factory number in front of me, but you can give Ted Eaton a call and he can help you out. By the way here are the spec's on mine, bore 3.862, stroke 3.600, rod length 6.300, deck 0, = 337.37 ci.
  6. hotroddon
    hotroddon
    Stock deck height is 9.77"
