deck lids; and the men that louver them.
Discussion in 'The Hokey Ass Message Board' started by tb33anda3rd, Nov 9, 2012.
  1. 7row lots of little ones
    31 vote(s)
    45.6%
  2. 5 rows of larger
    37 vote(s)
    54.4%
  1. tb33anda3rd
    tb33anda3rd
    buddy asked me to paint his roadster and TWO louvered deck lids. he asked that i make sure the inside was thoroughly painted. in the past i have set the spray gun to "garden hose" and flooded the inside, then blew it around with a blow gun with an 18" x 3/16 steel brake line for a nozzle. this time i decided to make a 180 degree nozzle for my shoots gun.
    1 what have you guys done?
    2 which deck lid do you like better?
  2. HOTRODPRIMER
    HOTRODPRIMER
    I think I like the 5 row better. HRP
  3. 4444Design
    4444Design
    like the 7 rows more
    awesome job btw
  4. brady1929
    brady1929
    seven rows, just like my avatar
  5. HomemadeHardtop57
    HomemadeHardtop57
    I like 7.
  6. tb33anda3rd
    tb33anda3rd
    after a couple coats, it started to seep out of the seams. another friend has one of those scopey things that he is going to bring over to double check we have not missed any spots on the inside.
    brady1929 and homemadehardtop57 how did you guys get paint on the inside?
  7. el Scotto
    el Scotto
    from Tracy, CA
    Seven for sure!!
  8. need louvers ?
    need louvers ?
    Seven, though many times I do six rows in the same spacing as the hood so it all matches front to back.
    32owner likes this.
  9. tb33anda3rd
    tb33anda3rd
    have you ever painted the underside before it gets put back together?
  10. need louvers ?
    need louvers ?
    I have primed the insides before re***embly, but I'm honestly not a paint kinda guy.
  11. farmer12
    farmer12
    I like the 5 rows better. Somehow 7 seems to be a little excessive IMHO.....
  12. 5window
    5window
    I voted for the 5, but I don't really care for louvered deck lids on a hot rod. Kind of like putting an altimeter on your dash. JMTC, but it's your car so don't give a damn.
  13. 60 Belair
    60 Belair
    I actually like both but 7 just seems a little busy, I Voted for 5, if I had to pick.
    Andy
  14. Rocky
    Rocky
    Classified Editor
    Next big step in my 34 ford coupe build is doing something about my decklid and the plan is to take the 2 bad lids I already have and strip them to make a decent inner structure.Then my bodyman and I will roll a new skin for it and send it to my ol, local buddy, Larry for a good louvering. We'll make a shallow pan under the louvered skin to direct water down through drains.
    Plan is to paint all the pieces before ***embly and then spot in the welded areas after ***embly. Finish paint will came last.
  15. 34 Hound
    34 Hound
    Don't forget a weep hole.
  16. DeLuxe 32
    DeLuxe 32
    5....7....Either way it will look awesome. I've got 9 in the back of my sedan !!
  17. ROBERT JAM
    ROBERT JAM
  18. tb33anda3rd
    tb33anda3rd
    good plan. do you think the inner pan is necessary? and will there be enough room?
  19. lurker mick
    lurker mick
    We welded the holes in the inner panel so no water could get into the trunk. I then painted both inner and outer panels with POR-15 to stop any rusting. Made sure there were drain holes in the bottom of the trunk lip that lined up with the drain holes in the body.
    5 rows of louvers were plenty to sand!
    Mick
  20. 5window
    5window
    Ok, so not to be a dumb fool here, I am sure I have missed something. Exactly what is the point of having louvers if you've welded everything up?
    Atwater Mike likes this.
  21. lurker mick
    lurker mick
    I won't judge on the dumb fool part, but the purpose of mine are like 99.9% of everybody else that louvers their trunk lids, I like the looks, but my wife didn't want her luggage wet if we get rained on when we go on trips.
    Mick
    32owner likes this.
  22. tb33anda3rd
    tb33anda3rd
    lurker mick, car looks great! the deck lids i had to paint came ***embled and did not have all the large holes that your have. they just have one access hole and cover on the inside, which is why i had to make the nozzle on the end of the hose to get paint down inside.
  23. The37Kid
    The37Kid
    Looks like a nice project Ted, like the gun adaptor. I voted for the 5 rows. Is that body perfectly balanced hanging by the top bow mounts? Bob
  24. tb33anda3rd
    tb33anda3rd
    this one isn't, there is a chain holding about two pounds of pressure to keep it level. the strange thing is the last one i did it held it perfectly balance without the chain in the back. maybe they used thicker sheet metal some where in the back? i made the cross brace to help in keeping it square while it is hanging, keep it in mind if you need it, or the gun.
  25. tb33anda3rd
    tb33anda3rd
    primer is on, underside is painted!
    my buddy decided on the 7 row...for this one.
  26. m.ralph
    m.ralph
    anyone in Houston,Tx or surrounding area doing louvers?
  27. DaveyJonez
    DaveyJonez
    from Houston
    “Louver Lou” he is on Facebook. I have spoken to him, haven’t had any work done by him yet.
