Decode my motor
Discussion in 'The Hokey Ass Message Board' started by Lucky Strike, Feb 28, 2007.
  1. Lucky Strike
    Lucky Strike
    This was stamped on the pad on the p***enger side of the front of my 327 sbc: CE7P27033 What does it mean?
  2. squirrel
    I think it means it's a crate replacement engine, so I can't decode it
  3. Brad S.
    Brad S.
    "Don't hide me in a truck."
  4. Lucky Strike
    Lucky Strike
    Ahwww BS I'll letcha peek at it every once in a while. Or you could give me that sweet roadster you got to put it in.
  5. Lucky Strike
    Lucky Strike
    Squirrel,
    It could be, but it came out of a 67 3/4 ton truck and the block casting number is correct for a 62-63 327.
  6. Other than a 57 265 engine the CE generally means CRATE ENGINE such as a replacement through over the counter or under warranty when new.
  7. 333 Half Evil
    333 Half Evil
    could find anything close to those numbers in any of my books...it could be a stamping from an engine building shop. there was one here by me that used to stamp all of the engines the built that way they could track/indentify them.
  8. Brad S.
    Brad S.
  9. Lucky Strike
    Lucky Strike
    Wow!!, turns out its an ultra rare corvette prototype motor with aluminum heads, intake and rods!!!
    ....Uh..just kidding...couldn't find it on there.
  10. Lucky Strike
    Lucky Strike
    OK, I looked up the block casting number on there and it says it is a 1962-62 250 horse 327. Humm.
  11. squirrel
    it's a replacement engine, you won't find the number anywhere, just get used to the fact that you have an unidentifiable oddball engine, and don't worry about it.
  12. Lucky Strike
    Lucky Strike
    Thanks, I feel better already.
    Well, I was planning on pulling the heads to replace the gaskets anyway.
    The caked on layer of dirt, grease, and grime that has fossils in it like the tar pits in California, is telling me that the original gaskets are still in there and still **** at preventing oil from exiting the engine.
  13. 68RATVT
    68RATVT
    from Clovis,CA
    I believe CE stands for counter exchange,the original motor failed under warranty and yours was the factory replacement. But who cares about numbers, it's a 327 man....rip the dam tires off...
