decoding a 283 chevy
Discussion in 'The Hokey Ass Message Board' started by chainsaw, Aug 26, 2013.
  1. chainsaw
    chainsaw
    I only have 5 numbers on pad on the block,, t107d if I'm reading it right. Can anyone decode this for me? The only thing I figured out is T=Tonawanda, 1=Jan, 07= 7th day ?. Not sure if that is right and I can't figure out what the d stands for. Thanks
  2. aojo
    aojo
    First letter generally denotes the month A=Jan B=Feb.... so t=??? If it read A107d it would translate to jan 10, 1957,,, the use of d in model year 1958 was for a two barrel 283 powerglide 185 horsepower for cars and trucks.
  3. F-6Garagerat
    F-6Garagerat
    Is t the first letter T for tonawanda Ny?
  4. mike in tucson
    mike in tucson
    from Tucson
    D means 58 thru 64 283 Impala powerglide 2bbl carb
    OR
    55-56 265 TRUCK 4bbl carb and manual ******
    Kinda weird but they reused the letter codes a lot back then
  5. 55 dude
    55 dude
    No side motor mounts it's a 265, 58 and up blocks were cast for side mounts.
  6. Hotrodbuilderny
    Hotrodbuilderny
    I am pretty sure the T is for Tonawanda, and the D would be a 58- 283 or as said possibly a 265 if no side mounts.
  7. chainsaw
    chainsaw
    It does have side mounts and it did have a 2 barrel so it must be a 58 to 64 283. Where are you guys getting the Impala part from? Thanks again.
  8. Hotrodbuilderny
    Hotrodbuilderny
    I've used Lutty's Impala Bob's.and a lot of online searches.
  9. chainsaw
    chainsaw
    Should there be more then 5 numbers ?
  10. squirrel
    no.
  11. chainsaw
    chainsaw
    Thanks again for the decoding guys.
  12. primed34
    primed34
    Check the numbers on the back of the block for more info.
